I am in the process of building a sub using two Rythmik servos in a sealed configuration. I wanted to go sealed, because I wanted the accuracy/transient response that a sealed enclosure offers. I chose to use two of them (in a single dual chamber cabinet) to make up for the output that is lost when choosing sealed over ported. I have, however, begun to wonder if I can't have the best of both worlds by using PRs tuned VERY low. Sealed, the servo kits have good extension, only 3db down @ 14hz:
![]() At such low frequencies, I'm sure they are excursion limited. I can't help but wonder if it'd be possible to throw a couple of 18" PRs in the cabinet, and mass load them enough to tune them around 8-10hz, and cause that curve to to remain close to the same, but just extend out a little bit at 14hz and below. It seems to me that if they are tuned low enough, the downsides of using a PR (group delay, etc.) would be kept well out of the audible range. Is this possible while keeping the cabinet at a reasonable size? I don't know how you'd even model this considering the effects the servo circuit has. Thoughts? |
#2 |
This isn't the "best of both worlds!"
It's really just a vented subwoofer, but in place of moving air in vents you are moving a mechanical PR. Ideally if this is what you want to do then a pair of 18" PRs should be placed on opposing sides. How about a vented sub designed using the approach suggested by Dan Wiggins? ie. low tuning and drooping response with low GD. Have you considered push pull mounting? Try vented first. If you don't like it, go back to sealed. If you don't like passive radiators, the price of entry is more and you have wasted money if you don't like it. If you like what you get vented, then you can always get PRs but I don't see much advantage unless you have trouble building a port that doesn't chuff. As to how to model it ... start in WinISD and model Brian's suggestions on the website in a vented box. Then do a model in the same size box with a PR and experiment until the PR box is almost identical. Then you have your design. If you can't allow for the impact of the filters included in the kit, at least copy the vented design as I'm sure Brian will have already accounted for that. I'm sure as well that he will help you out with it.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#3 | ||||
![]() Quote:
Thanks!
#4 |
Take a look at the AE Speakers passive radiators, which are designed to use very high moving masses. 18" PRs sound about right for what you're trying to do, but I wouldn't tune in the single digits. The Rhythmik setup's subsonic filter only sets as low as 14 Hz or thereabouts, if I remember correctly. So your tuning in the single digits wouldn't do much good.
#5 | |
#6 |
Ok I misunderstood a little regarding the "best of both worlds." Sounds like an interesting idea, although I wouldn't take it too far, nor would I be concerned that there is output useful at 20 Hz from the PRs. In fact I'd still suggest trying this out. I think you are getting into territory where experimentation wins over simulation.
How about making a big test box - say 120L per driver and tuning ~ 12 Hz. Because the tuning is so low the vent velocity is quite low and you can use a 90mm vent. In fact in that size box such a vent will be ~1m long and at xmax, velocity is 7m/s @ 20 Hz and peaks at 17m/s @ 11 Hz before the 14 hz filter - in other words you could throw in a 1m PVC vent @ 90 mm and test it out. If you like the results you get you can then go with a PR. How do you know your sealed version is actually better than a vented design?
#7 |
Well, part of my impatience Saturday was simply second guessing whether or not I could improve it before I actually spent more time building the cabinet. I've since convinced myself I'm heading in the right direction, and almost have the cabinet done. It's all I can do to get this project done, so I probably shouldn't sidetrack myself to satisfy my curiosity.
As far as the last question, without opening up any of those old sealed vs. ported debates, lets just say that I believe that a good sealed system has a better chance of being closer to the characteristics that are important to me at this point than a good ported system.
| Rythmik Servo Sub Kit #1 | audioferret | Subwoofers | 2 | 27th January 2007 07:39 PM |
| Shiva or Servo Rythmik for Sonotube? | Ang | Subwoofers | 9 | 16th March 2006 05:29 PM |
| New Sub finished with Rythmik Servo kit. | basham | Subwoofers | 14 | 5th March 2006 11:31 AM |
| My dual Rythmik Servo sub is complete! | dscline | Subwoofers | 19 | 15th February 2006 06:43 AM |
| Page generated in 0.13250 seconds (81.75% PHP - 18.25% MySQL) with 10 queries |
