Old 9th December 2005, 07:55 AM   #11
paulspencer's Avatar
You added a resistor permanently?!!! Isn't that a bit of a problem with power handling?
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 9th December 2005, 05:42 PM   #12
yes permanently and no to power handling. The resistor was a small value to make a fine adjustment to the speaker Q. I cannot recall the value but I used a short length of resistance wire inserted into one side of the speaker cable. It may have been 0r1 to 0r3, that sort of order spread over about 120mm of cable length. So heat is not a problem nor is power reduction. Hi Fidelity is more important.
It is only fitted to the bass cable since I have only run bi-wired or bi-amplified for very many years. The treble and mid units were not corrected.
regards Andrew T.
Measuring Speaker Parameters, How to? Tall Shadow Parts 5 10th December 2006 09:20 PM
measuring t/s parameters bigcatdairy Multi-Way 7 9th December 2005 01:57 PM
measuring tweeter parameters? synergy Multi-Way 0 23rd March 2004 11:28 AM
Measuring the T/S parameters using an osciloscope red Multi-Way 1 9th March 2004 11:27 PM
Page generated in 0.06743 seconds (67.22% PHP - 32.78% MySQL) with 11 queries
