Old 8th December 2005, 04:23 PM   #11
Tweeker is offline Tweeker  United States
This is the 12" woofer I planned to use.
Be sure your foil hat has a good low impedance ground.
Old 8th December 2005, 04:42 PM   #12
http://www.audioasylum.com/forums/hu...ges/97895.html
Old 8th December 2005, 05:28 PM   #13
Claus is offline Claus  Denmark
I have listen to subwoofers that where cut at more then 300hz without any placement problem. The woofers where placed in corners and where time aligned to the main speakers, with a delay line for the main speakers (A digital crossover/roomcorrection are mandatory, fx. Tact RCS). I think the time aligment is the main factor for succes.
claus
Old 9th December 2005, 11:10 PM   #14
Kittle is offline Kittle  United States
My own listening tests gave me a cutoff point of 135hz when I could actually tell where the sub was sitting based on sound.
being that I usually use a cutoff of 100hz or so, its not a problem.
Old 11th December 2005, 05:44 AM   #15
paulspencer's Avatar
Also consider how accurate the driver is up that high. I find better performance when I cross low ~ 40 Hz or so. I have tried crossing up at 80 Hz with a 4LR and didn't like the result. IMO you need a very good driver to cross higher than this for anything other than home theatre LFE use.
I don't know anything about that driver you linked, but it does look good for OB line array use. Perhaps make it a 3 way OB then cross to a sub in the midbass somewhere ~ 40 - 60 Hz. If you make the woofers a U frame you can get an fequal down to 60 Hz without it being too big.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
High efficiency subwoofer hawkeyefile Subwoofers 34 11th August 2008 09:21 AM
High efficient subwoofer design DaveCan Subwoofers 88 14th December 2007 11:24 AM
SURVEY: how high can your subwoofer go? paulspencer Subwoofers 0 5th October 2005 09:08 AM
High SPL Car Horn Subwoofer Astro Power Subwoofers 42 9th November 2004 04:00 AM
Page generated in 0.07558 seconds (71.51% PHP - 28.49% MySQL) with 10 queries
