Tempest vented EBS subwoofer
Old 22nd October 2002, 07:17 PM   #31
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by BrianGT
If I have any problems, I will add more wood inside of it as Dave mentioned.
Make sure you add it before you put the finish wood on it. Also keep in mind that by adding mass to the panels you will lower the panel resonance modes and need the extra bracing even more.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd October 2002, 07:45 PM   #32
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I would do it now... but I don't have access to a table saw. I am planning on trying it out without the extra braces for now, and not finishing it with the extra birch yet. Then if I can find time in the next couple of weeks to get access to a table saw I will do it.
Will the stuffing help eliminate this problem? Should I put stuffing on the internal braces, or just the sides (I was planning on only the sides).
Brian
Old 22nd October 2002, 08:01 PM   #33
frugal-phile(tm)
planet10's Avatar
No it won't -- it will only help kill higher freq stuff. I'd try some on the braces. Damping in the exact middle of a box is one of the most effective places for it.
Old 25th October 2002, 03:05 AM   #34
BrianGT's Avatar
The sub is assembled (not finished yet), and I put it in my '98 honda civic hatchback (barely fits). I am driving it with a 360W rockford fosgate amp that i got 3 years ago.
The sub is loud... It shakes the crap out of my car. I have to get out of the car and turn it up with the remote control. It goes pretty low.
I got my 2 leach superamp boards fixed (skipped a jumper and one side was clipping way too early). I also tested my power supply. All that I need to do to it is assemble. It should put out around 500W into the 4ohm load with the bigger transformer.
I am not going to worry about the extra internal braces, as I am probably going to sell the sub to a friend and build another one... (a little smaller next time). I am satisified with the quality of the tempest vented enclosure in the car, and it probably isn't broken in yet. I had to dig out the ear plugs to bear the excessive bass that it puts out. I also couldn't find an available table saw.
I will post pictures on my website in a couple of days. I am finishing my Seas Thor TL speakers for the DIY2002 Atlanta show on saturday (almost done, just need to finish compounding them to get a nice smooth finish).
I have the box cut out for the mid-Q sealed tempest (a bit smaller then 2'x2'x2') and it has a similar mid brace. What is the best way to modify this sub before I put it together. I had an extra sheet of mdf at my friends, and I all of the pieces for the sub with it.
Brian
Old 25th October 2002, 04:04 AM   #35
frugal-phile(tm)
planet10's Avatar
Beauty. Watch out it could turn into a side job
If you can divide the panels into unequal trapezoids (ie an angled brace). Use irrational numbers. For example you could place a brace at 1:1.4142 of the panel and then rotate it about its centre to create placement of an angled brace with a predominantly irrational placement.
Hope that makes sense -- i've been doing such things as 2nd nature for so long ...
dave
Old 25th October 2002, 05:24 AM   #36
BrianGT's Avatar
Dave,
I really appreciate your advice. I will definately consider it before I start the sealed tempest.
Here is a pic of the sub now. The main baffle is flush except for the speaker jack, because i didn't take the time to make a square countersink hole. I will add the 1/4" birch to the sides next.
Brian
Tempest vented EBS subwooferHide this!Advertise here!
Exodus Tempest-X 15" Driver / Subwoofer mp006ltk Swap Meet 1 22nd February 2009 08:46 PM
New CSS SD12 Vented Subwoofer Timn8ter Subwoofers 9 31st January 2007 08:02 PM
Diy amp to power tempest subwoofer postman Chip Amps 7 30th March 2004 03:30 PM
FS: Adire Audio Tempest EBS subwoofer BrianGT Swap Meet 6 21st July 2003 12:15 PM
Tempest subwoofer for sale (Adire alignment) Darren_T Swap Meet 3 3rd April 2003 05:49 PM
