Old 9th December 2005, 11:03 PM   #21
Relax is offline Relax  United States
why would you want a higher loss? or is that the panel's reverse output below the drivers output?
Like:
The driver puts out 100 db, at -25db from panel, meaning 75db output heard?
or the panels output 75db of negative wave?
or 25db of opposite signal?
Old 9th December 2005, 11:05 PM   #22
Right, the panel output is opposite of the drivers', so you want it low
Noah
Old 9th December 2005, 11:13 PM   #23
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
I'll clarify
Noah means when the driver's output is 100db then the panels' output is 75db. The panel output is 25db lower thus -25db relative to the driver.
The golden rule of DIY:
Build nice, or build twice!
Old 9th December 2005, 11:18 PM   #24
dscline is offline dscline  United States
Originally posted by noah katz
A few months ago I did FEA (finite element analysis) of a 16 cu ft sealed box made from 3/4" plywood, for a pair of Avalanche 18 drivers. ... I was hoping to satisfy myself that an unbraced box would be fine.
I've been concerned by some of the things people have said that I'm not planning enough bracing. But that's a size I would have never considered to do w/o bracing, so now maybe I'm not so far off.
I'll just cut to the chase. I'm building a box that is a tall slender column: about 15" square by about 36" high, which will contain two 12" drivers, but it will be separated into two separate chambers. So essentially, I'm looking at two 2.1 cu ft boxes with a 12" driver each. But the divider panel in the middle of the column will be arranged at an angle, so the largest panel in each section will be about 25" x 15". All other panels will be smaller than that. So how much bracing would people suggest? Based on the previous recommendation of 6-12" between braces, the 25" panel would need two braces. To me, that seems like overkill for this small of a box.
Old 9th December 2005, 11:20 PM   #25
BassAwdyO's Avatar
One brace should be fine. I wouldnt even put braces on 15" panels.
Old 14th December 2005, 05:34 PM   #26
Send a message via AIM to wunderaa
Dry Assembly
Old 14th December 2005, 05:36 PM   #27
Dry Assembly 2
Old 14th December 2005, 05:39 PM   #28
Drivers
Old 14th December 2005, 05:41 PM   #29
Enclosure before bracing
Old 14th December 2005, 05:47 PM   #30
This is my DIY amp that will be driving the subs. Only about 1/2 way done right now.
BIB questions (construction and otherwise) crappyjones123 Full Range 11 23rd August 2009 06:14 PM
Construction technique? g(f(e)) Tubes / Valves 1 27th January 2008 04:06 AM
Construction technique straight horn mashaffer Subwoofers 5 14th June 2006 05:25 PM
Construction questions TonyW Multi-Way 3 16th June 2005 03:29 AM
Page generated in 0.11778 seconds (70.33% PHP - 29.67% MySQL) with 11 queries
