Old 1st December 2005, 08:13 PM   #11
Speakerholic
Cal Weldon's Avatar
How about PA horns? Now were talking volume vs depth.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd December 2005, 02:00 AM   #12
paulspencer's Avatar
JJ, I have plans for a 35 Hz horn for the tempest driver that were on the adire website in the past, I can send it to you if you like. If you don't mind changing the driver over from time to time then you don't even need to buy a new driver.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 2nd December 2005, 02:07 AM   #13
Send a message via MSN to noodle_snacks
Yeah i have those plans, I have been fiddling around with horn resp etc, i have about 800 bucks or so to spend, my options are either to build stereo XLS/XXLS subwoofers at home (or some other sub driver). Then build the tempest horn. I could also build a horn subwoofer or two using lower quality drivers and keep them for that sort of use. The sound quality of the horns does not concern me very much, i primarily want a 40hz cutoff and high efficency, both of which are easy enough obtain i think.
Old 2nd December 2005, 02:25 AM   #14
A nice combo would be a bass horn to cover 40-80 Hz then use it also at home to go in between your EBS and mains. Not so much for output at home but as a bonus it will give very low distortion in the mid to upper bass, if it's a good horn it should sound quite a bit better than the tempest in that range. How big can this thing be?
Old 2nd December 2005, 12:14 PM   #15
Hmm with my amp that would be easy enough to do (2x450wrms into 4 ohms) Biggest dimensions are about 1000x1400x800 or so total (so it'd fit in the car) however i'd rather build a 2-4 of something this size:
http://diy.cowanaudio.com/hornsubjr.html
Unsure of what sort of driver to use though (looking for suggestions, pointers here).
While using this stuff in a PA arrangement i would be using some PA main speakers with whatever sort of horn subwoofer i decide to go for, having better quality bass down to 40hz is just a bonus.
Looking for efficiency subwoofer Cyberzim Subwoofers 11 13th July 2009 01:25 AM
Hi Efficiency two way? Godzilla Multi-Way 24 15th August 2008 04:02 AM
High efficiency subwoofer hawkeyefile Subwoofers 34 11th August 2008 09:21 AM
Subwoofer Efficiency hendrix_fan_no1 Subwoofers 2 4th October 2005 10:14 PM
High Efficiency Subwoofer Design john van ommen Subwoofers 1 19th September 2005 03:29 AM
Page generated in 0.07790 seconds (74.64% PHP - 25.36% MySQL) with 11 queries
