Old 2nd December 2005, 08:31 AM   #11
damo21 is offline damo21  Australia
I got the XLS 830500 12", I'm thinking I'll build an 88L sealed like the shiva design specs and see what it sounds like.
Old 2nd December 2005, 09:53 AM   #12
paulspencer's Avatar
It's not a driver to be under-estimated. Colin Whatmough used it in his signature speakers going for ~$25k. They should very very accurate if done right.
Have a look at the wiki ... there is enough info in there to take some guess work out of it, integrate it properly and get a vent that doesn't chuff.
If you want to build a test sealed box, then start with a volume that gives a Q of 0.5 - critically damped. That's a good place to start. A quick WinISD sim will tell you what net volume you need.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 2nd December 2005, 10:47 AM   #13
Are Colins subs vented? I read the wiki, maybe I'll try vented 90mm pvc with huge port flares.
Old 2nd December 2005, 11:08 AM   #14
No they are sealed.
100mm PVC vents are a good starting point in a box large enough to fit them in ... perhaps 85L with some 36mm vents. I'd check with the flare chuffing calculator you can download from Collos site - there is a link on the wiki, and check with WinISD that you can get the vent velocity down enough.
a 100mm vent with 60mm flares should handle 34m/s,
and I'd say you should be able to get it down below that with the XLS
Horizontal MTM Center channel: avoiding off-axis nulls DcibeL Multi-Way 27 10th October 2009 05:57 PM
Flux Damage jkeny Parts 11 26th March 2008 04:57 PM
paralleling capacitors and avoiding resonance zilog Power Supplies 8 25th October 2006 12:02 PM
damage the laser? maya1 Digital Source 0 16th June 2004 06:09 PM
avoiding the l-pad smak Multi-Way 6 17th May 2004 03:16 PM
Page generated in 0.09183 seconds (67.09% PHP - 32.91% MySQL) with 10 queries
