Old 3rd December 2005, 03:17 AM   #21
GM is offline GM  United States
GM's Avatar
Originally posted by damo21
Hey Paul, some dude from Netherlands seems to have a more accurate model of GD threshold... GDmax(ms) = 400 / f (hz)
Greets!
Bell Labs/W.E. did extensive testing in the mid '30s and concluded that anything < 3 ms in the 350-800 Hz BW where they XO'd their various studio and cinema horn combos was inaudible. Factor in that our ears are very non-linear and that I could hear as little as 0.1 ms difference at 2 kHz when I was much younger, I don't put much stock in this 'model'.
As always though, YMMV.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 3rd December 2005, 08:59 AM   #22
damo21 is offline damo21  Australia
I'm more interested in GD below 60Hz because this is the subwoofer forum! I was drawing attention to pauls "extrapolated" data for low freqs which someone disagreed with.
Old 4th December 2005, 08:52 AM   #23
The model suggested by Rademakers: GDmax=400/f is in agreement with this, in fact it suggests a lower threshold in that frequency range to be even safer.
The model suggested by Rademakers almost fits your experience, suggesting less than 0.2ms at 2kHz. The proposed model is quite non-linear aimed to match the differing ear sensitivity to group delay for various frequencies. Keep in mind, this thread was focusing on GD below 60Hz so the fact that the model almost fits your experience at 2kHz is pretty good.
Please see my earlier graph.
Old 6th December 2005, 02:05 PM   #24
paulspencer's Avatar
GM,
If you have a look at the article by John Murphy you will see that the Bauert and laws study tends to agree at that level. As you go down in frequency, there is a relationship between GD and frequency that is not linear. Rather, in each range covered they looked at cycles, with about 16 cycles at the top end and about 1 or 2 down low.
If you look into it, the values I put down aren't unreasonable, however, I'm not going to stand behind them if someone does a credible study showing otherwise. I just think this is the best that we have to go with so far that I know of.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 7th December 2005, 01:27 AM   #25
GM's Avatar
Greets!
?! I don't see how any of this applies to my response beyond being insulting.
GM
Old 7th December 2005, 02:07 AM   #26
GM's Avatar
Greets!
Hmm, 600%/800 Hz, 100%/2 kHz difference respectively fits Bell Lab's and my experience?! I think not! Since our hearing acuity rapidly falls off below ~200 Hz, it seems reasonable to me that the formula can only increase in error with it, but like I said, YMMV.
As for 'safer', this implies that you're willing to give up considerable acoustic gain down low where we typically need it most to keep GD low, just on the off chance you might be able to hear it. This seems 'penny wise and pound foolish' to me, but again, YMMV.
GM
Old 7th December 2005, 02:16 AM   #27
GM's Avatar
Originally posted by paulspencer
GM,
Greets!
?! What is it with you guys? Where have I made any comments WRT what you've posted on the wiki, which I haven't browsed yet BTW?
GM
Old 7th December 2005, 03:16 AM   #28
Here is the original article on which those values are based:
http://www.trueaudio.com/post_010.htm
scroll down half way and you find a table of "cycles on delay"
8k > 2ms > 16 cycles
4 > 1.5ms > 6
2 > 1 > 2
1 > 2 > 2
.5k > 3.2 > 1.6
Notice how the cycles go down. Now we have 2 octaves to extrapolate down before we get to 120 Hz and 3 to get to 60 Hz.
John says:
Extrapolating the Blauert and Laws data to lower frequencies it could be that "one or two cycles" of delay continues to be the threshold as we move lower in frequency.
and further ...
My current opinion would go something like this: "One cycle or so of delay in the bass range is probably just audible under controlled listening conditions (phones) and with the most challenging program material (clicks and pops). Under less well controlled listening conditions and with less difficult program material the audibility thresholds are somewhat higher."
I have used the one cycle of delay guestimate to derive those figures.
Bauert and Laws came up with 3ms for 500 Hz which seems to be fairly close agreement.
How the data can be extrapolated is another matter, and if indeed it can be extrapolated at all.
I find it surprising that no one has done a study on this for bass frequencies.
For now, this is the best that I can find. I'm wary of rule of thumb guidelines here as I don't know what they are based on.
I'd like to know how much GD is audible down low, since like GM indicated, there's no sense giving up low end extension to get low GD numbers if you can't hear the difference.
EDIT: I have a spreadsheet showing the extrapolation and anyone is welcome to see it and comment. Just shoot me an email. It should be noted that a different extrapolation can give very different results, and how you do this may effect whether or not the GD in a particular design is considered audible or not. The values in this wiki suggest that it's possible to get down low with a vented box and for the GD to be inaudible.
Wiki Changes davidallancole Solid State 5 26th September 2006 03:01 PM
What Wiki? Pbassred Tubes / Valves 4 25th September 2006 05:27 PM
Wiki pinkmouse Forum Problems 1 20th March 2005 01:03 PM
Nobody uses the wiki! DragonMaster Everything Else 8 16th November 2004 07:11 PM
OT (badly) Wiki Wiki jackinnj Everything Else 0 26th June 2002 04:50 AM
Page generated in 0.14081 seconds (83.17% PHP - 16.83% MySQL) with 10 queries
