4th order bandpass with PR
Old 11th November 2005, 12:56 AM   #1
tade is offline tade  United States
Send a message via AIM to tade
Default 4th order bandpass with PR
http://www.cinenow.com/us/materiel.php3/tid,4/id,2370/
That is interesting, a fourth order subwoofer with a PR instead of a port. Is this a viable DIY design? I have never seen it before.
Old 11th November 2005, 06:42 AM   #2
simon5 is offline simon5  Canada
Why not?
DIYaudio for President !
Old 14th November 2005, 01:08 PM   #3
John_E_Janowitz is offline John_E_Janowitz  United States
Send a message via MSN to John_E_Janowitz
Yes, you can easily do this. I experimented with both 4th order and 6th order bandpass using PR's about 5 yrs ago. The only problem is that you're still limited in output by the PR itself. A properly designed port can usually more more air than a single PR the same size as the active. If you ended up with a 12" woofer and dual 15" Pr's then you'd have some advantage. Per the amount of enclosure volume though you'd end up with more output to just do a standard PR enclosure with a pair of PR's. The bandpass has the advantage of increased efficiency over a given range but gives up a lot of the extension.
John
4th order bandpass with PRHide this!Advertise here!
6th order bandpass Chris8sirhC Subwoofers 1 13th September 2008 07:09 PM
6th Order Bandpass HT Sub, would like some feedback pjpoes Subwoofers 2 3rd September 2008 01:55 AM
4th Order Bandpass Help berserker Subwoofers 9 19th January 2007 03:56 PM
4th order bandpass 4 way the phantom Multi-Way 3 27th July 2005 06:28 AM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
Copyright ©1999-2017 diyAudio
