Old 10th November 2005, 02:18 PM   #1
Volenti is offline Volenti  Australia
Default Query regarding "stacking" T-lines
I'm building a dedicated Home theater (all speakers DIY) and am up to the fun bit, Bass .
Here's the plan, 8 budget but competent 12'' drivers each housed in individual T-lines that, when stacked, literally make up the front wall of the room with the projector screen mounted in front. (see attachment)
My question is; is this configuration going to do anything weird? I'm mainly looking at the open end of one line being right next to the driver of another.
I'm using Martin Kings mathcad files for the line design, I have actually already made a single line for one of these drivers (before I had access to the software) that's 3/4 of the planned length and it sounds pretty good.
Old 10th November 2005, 02:20 PM   #2
This is the response I get in mathcad, note no fill is used and this is only used for ~60-70hz and below, I can take care of the peak with a steep X-over.
Old 10th November 2005, 02:21 PM   #3
The mathcad parameters used;
Old 10th November 2005, 03:06 PM   #4
bwbass is offline bwbass  United States
A little stuffing in the driver end of the line will go a long way towards taming that peak. Don't worry, you'll still have plenty of bass!
Old 10th November 2005, 11:39 PM   #5
Tweeker is offline Tweeker  United States
Moving the driver a bit more from the furthest end of the pipe can also help. 1/6 of the way to the other end, for example.
Old 11th November 2005, 03:18 AM   #6
I'm not overly concerned by the peak, I can either address it electronically or mechanically (or a combination of both)
The drivers can't be offset since they would then end up behind the screen with this setup and the screen isn't acoustically transparent (DIY glass mirror painted screen)
Though with the drivers mounted in the sides rather then the end they will be off set a little anyway. (the test line is similar and it's peak isn't problematic)
What is a potential concern is the physical orientation of the "stack" in the room, and how that will effect the acoustics of the end result. The room is 2.6m H x 3.4m W x 5.2m D (7.8' x 11.1' x 17') Considerable broad band bass trapping will be implimented ,approx 7-10% of room volume (some external to room dimentions)
suggestions/comments appreciated
Old 11th November 2005, 08:27 PM   #7
If Im understanding it all right, it looks like it will be pretty corner loaded. It wouldnt be too shocking to see some room mode issues, further complicated by stereo sub source, but Im no room interaction expert. You cant move the subs much to adjust in this setup. Nevertheless its a neat concept. An infinite baffle or dipole setup might be worth considering as an alternative should this prove too nettlesome.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Stacking a LOT of 3" speakers? Mikael Abdellah Multi-Way 34 22nd August 2007 07:08 AM
"Stacking" TDA1543 john65b Digital Source 16 8th October 2006 02:52 AM
EM84 based VUmeter "lines" don't go to zero Danko Tubes / Valves 6 20th August 2006 10:29 AM
Page generated in 0.08239 seconds (82.72% PHP - 17.28% MySQL) with 11 queries
