Old 1st November 2005, 08:46 AM   #1
paulspencer's Avatar
Default how to go from horn response to a folded bass horn design?
I have a few Q's about going from a bass horn "design" with some numbers and charts in horn response ... to a design that can be built.
Does anyone have forumulas for the different contours?
Has anyone tried a folded horn where there are no parallel sides? (tricky yes)
Suppose I wanted to stack a number of horns to make up the required horn mouth area. How close do the mouths need to be in order to couple? 1/4 WL apart?
Is it better to stack smallish horns, with the necessary length, small 8" drivers and making up the combined mouth size ... or a single larger horn with a bigger driver?
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 1st November 2005, 03:23 PM   #2
slowmotion's Avatar
Default Re: how to go from horn response to a folded bass horn design?
Hi
You allready have that function in Hornrespons;
When you have calculated your horn, go to "Window",
then "Schematic Diagram" . When in "Schematic Diagram"
go to "Tools" and point to "Export". A txt-file will then be made
with the horn contour. You will it find in the Hornresponse
folder under "export".
Several spreadsheets can be downloaded from the web,
but we've talked about that in an earlier thread,
so I'm sure you've checked those out allready
cheers
Old 1st November 2005, 09:35 PM   #3
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
I do it in CAD,starting at the mouth,going 'x' distance in depth,and following the expansion around,approximating it as parabolic/conical sections.
Old 2nd November 2005, 07:41 AM   #4
How do you approximate the curve to straight line segments? What kind of resolution?
Old 2nd November 2005, 02:30 PM   #5
Paul,
I would think you have probably seen this, but in case you haven't, or lost link etc, this page describes how I do it (using Autocad, but the same principals can be used manually). The spreadsheet there may also be of use.
Cheers
Graeme
Old 3rd November 2005, 11:23 PM   #6
mike.e's Avatar
My horns are 2Das its easier to make,and Qcad 1.5 only does 2D as far as I know.
My method is fast once you know it.
Graemes method is fancy and good but I dont have autocad2002 nor want to relearn it,it was most un intuitive and slow.
I draw a straight line from the mouth to the point at which the corner begins. This forms a parabolic expansion. Then I estimate that the path length is formed at 1/2 the corner radius,and the area will decrease as the horn turns the corner. Then I might put a corner reflector in,or not if its only a 2 or 3 octave basshorn.
And carry on,with whatever folding scheme. It works for bass. Basshorns sound funny when folded so theres no real worrys about trying to make perfect corners,just keeping the area approximatly correct is enough.
Old 4th November 2005, 03:54 AM   #7
Graeme, I haven't seen that link, thanks.
Old 4th November 2005, 09:19 AM   #8
slowmotion's Avatar
Hi
Very nice post by Tom Danley here:
http://www.audioasylum.com/forums/hu...ges/96159.html
cheers
Old 4th November 2005, 11:44 PM   #9
mike.e's Avatar
http://www.geocities.com/xobt/TD.rtf
http://www.diyaudio.com/wiki/index.php?page=Bass+Horns
How to design folds in rear loaded bass horn tstt9000 Multi-Way 3 26th August 2007 04:59 PM
Comments on bass horn sim in horn response paulspencer Subwoofers 38 1st November 2005 09:34 PM
The best BASS HORN Design . darkm4n Multi-Way 14 27th March 2004 09:14 PM
18" Folded Bass Horn Design djdan Multi-Way 11 27th October 2003 10:21 AM
FS: Wicked One bass horn (decware design) cm961 Swap Meet 0 11th August 2003 04:17 PM
Page generated in 0.11023 seconds (83.79% PHP - 16.21% MySQL) with 10 queries
