Hi
I want to simulate a woofer in a closed loop by use og an accelerometer, and need a driver model for this. I've found one (attached) buth the frequency responce seams very limited (breaks at 30Hz+), so I assume it isn't correct. Do you have a better model? Regards Kaspar |
#2 |
Leach's Computer-Aided Electroacoustic Design with SPICE should give you an idea. Have a look at his site for other material as well; particularly the article regarding lossy voice-coils.
Remember that these models are only valid up to frequencies just before cone breakup. Moreover, these are small-signal models. Enjoy
Crossover/Subwoofer Simulator |
#4 |
Thanks I'll have a look at it
#5 | |
Banned
The simulation is for two systems that are identical in every way except that one circuit includes the effects of a (lossless) voice coil inductance and the other neglects the inductance. The driver parameters are entered via the SPICE ".param" directives in the lower-left column. From these parameters, CMS, MMS and RMS are calculated. The box volume in cubic feet is entered using the "VBcuft" parameter, which is set equal to 3 in this case. A few LTspice quirks are worth mentioning here. If one uses current-controlled sources (CCCS "F" source or CCVS "H" source), one must provide an independent voltage source of value zero Volts to sense the current. A positive current means it's going into the positive terminal of this zero-Volt source. The "F" or "H" source must specify the reference designator of this voltage source in its "value" field. See for example the H1 and H2 sources. These implement e=BLu and f=BLi respectively. Voltage source V2 senses i and V3 senses u. Also note how V2 and V3 are referenced in the "value" fields of H1 and H2 respectively, along with the BL product. Here's one thing to beware of. If you copy a circuit containing a current-controlled source, the "value" fields are not "fixed up" to reflect the voltage source in the new, copied circuit. Rather, they reference the original voltage sources. So if you do such a copy, you'll need to "fix up" these reference designators manually. Looking at the lower circuit, current source F6 senses the velocity of the cone, while C6 integrates it to get displacement, and scales the displacement to units of mm. Current source F2 senses the volume velocity, which is differentiated using L3. The value of L3 is chosen by using equation 4.17 from Beranek, which is for a piston in an infinite baffle. The pressure in this equation is scaled to an RMS value, then divided by 2e-5 N/m2 and the off-axis angle is set to zero. The distance used is one meter, and the result neglects the excess phase from the propagation velocity of sound and the corresponding distance. The distance can be changed via the "dist" parameter. If the voltage applied to the voice coil is 2.83 Volts RMS (4 Volts peak), the voltage measured at out1, when expressed in dB, corresponds to the dB SPL using the normal convention of specifying sensitivity. That is why the voltage sources specify a value of 4. To get displacement in mm, the left axis of the graph of the voltage at out2 must be displayed in linear form, rather than dB. These same considerations apply for out3 and out4 in the upper circuit. If you want to see the calculated values of CMS, MMS and RMS, you'll need to switch over to operating point analysis. Run the simulation and do a View, SPICE error log. The computed values of these will show up, courtesy of the ".measure" directives on the lower right. In order for the operating point analysis to succeed, I had to place a large resistance in parallel with the capacitors having value CAB (C2 and C4). Right-click on these and you'll see they're set to 1e12 Ohms. Of course, programs like WinISD can get all these data and much more, with less effort. But SPICE offers lots of flexibility and power if you want to get fancy and look at things these programs can't. This example wasn't meant to be comprehensive, just to illustrate the concept of how to set the problem up. Edit: Oh yeah, one thing I forgot to mention. All driver parameters are in MKS units to minimize confusion and chance of error. So for example, the units of SD are square meters, not the square cm usually seen. |
#6 | |
Hello,
You may give a look to: http://pagesperso-orange.fr/jm.plantefeve/simul-hp.html Best regards from Paris, France Jean-Michel Le Cléac'h Quote:
#7 |
#8 |
This is also useful:
http://www.shine7.com/audio/orcad.htm Cunningly uses Unibox to calculate some of the mechanical parameters from the Thiele/Small values |
#9 |
Is andy_c out for good - that would be a shame. Nice model he came up with there. From memory, the main model for the driver and box looks to be right out of Small's work, just wanted to confirm that.
| Driver Electrical equivalent circuit to design xover | andy2 | Multi-Way | 8 | 24th July 2010 08:15 AM |
| Can you tell a driver model from the front? | macaque | Multi-Way | 1 | 17th July 2007 06:44 AM |
| T/S conversion from acoustic to electrical lumped model? | teemuk | Multi-Way | 11 | 17th February 2007 06:28 PM |
| Autocad 3d Model of any woofer driver? ANY? | ssabripo | Multi-Way | 7 | 4th January 2006 01:04 PM |
| I got driver from germany. can u tell me what brand and model is it? | jinkuchi | Multi-Way | 3 | 10th September 2005 05:43 PM |
| Page generated in 0.11549 seconds (83.08% PHP - 16.92% MySQL) with 11 queries |
