I was wondering (not that is possible):
You build a sub with helium in it, the weight of helium is a factor 7 lighter then the air. So the speed of sound in helium is much slower. In fact if the speed is also a factor 7 slower then it is in the air then it should do ~47m/Sec. That means that if you build a TLsub for about 30 Hz it would normally takes a tube of ~2,75meter, but with helium it should only take 0,39meter. But because its helium and you want to keep the helium inside, you want to build a closed sub. And if you want to build a closed TL you must build it twice as long. But even then you get a sub thats only 0,78meter. Just a theory... but is it true? |
#2 |
When you fill your lungs with helium and speak, you speak in a very high voice. Remember that your voice is given by resonant properties in your larynx, sinuses, etc as well as the frequency of vibration of your vocal chords.
This suggests to me, then, that the Fs of the enclosure will go *up* when filled with helium. Just a guess, though. It's possible that there's some kind of frequency shift going on when the expelled helium meets regular air, I don't know enough physics to know for sure. Wes
Do daemons dream of electric sleep()? |
#3 |
So what you are saying is that I have to use a gas thats heavier than air to create the effect?
#4 |
I just looked on google and it turns out the speed of sound in helium is 970 m/s..
In argon it's 319 m/s, neon is 435 m/s. |
#5 |
okay so with helium the sub gets even longer (that can't be good)
I could not find that with google (wich keyword did you use?) so I have to look for a gas thats heavier... but still the big question; would this work? |
#6 |
I searched for 'speed of sound in helium' etc
#7 |
How do you keep it sealed?
#8 |
The speed of sound in sulfurhexafluoride would be about half that of the speed of sound in air. Due to it's inertness and price it would probably be the best choice.
Wkr Johan |
#9 |
you live with a billionth of a part of your air as sulphure hexafluoride. I bet it has a terribly bad odor! I would go for uranium hexafluoride. Much better smelling. go ahead, smell it.
#10 |
If the sub were completely sealed(which it would HAVE to be for this idea to work) then you wouldnt be smelling what was inside. Take for instance a bottle of colonge, if the bottle is COMPLETELY sealed, can you smell colonge through it? Not unless some is on the outside
The golden rule of DIY: Build nice, or build twice! |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 08:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 10:52 AM |
| build or buy | navin | Multi-Way | 9 | 16th November 2004 05:36 AM |
| Page generated in 0.10505 seconds (78.32% PHP - 21.68% MySQL) with 11 queries |
