#31 |
On the bright side SF6 is harder to arc in than most gases. SF6 is also a very potent greenhouse gas.
#32 | |
It's used in electric insulators, even in the breakers of 100kV+ devices. If it would break down, it could only break down to the elements it consists of. Perhaps my chemical knowledge isn't extended enough but it seems strange that it would break down from a very stable compound into one of the most reactive elements possible (totall 2 of course). In other words the opposite of the foundation for predicting the behaviour of molecules by means of electronnegativity and sharing electrons. In electrical insulators by example, it would mean that it wouldn't insulate at all, but would attack and eventually destroy the metals it would be assumed to protect, unless the reaction is irreverseble enough to immidiatly react to the compound ones again. On basic chemical and physical properties I would put it in the same class as CFK's and Teflon (carbon surrounded by fluorine). All substances that are known and used for there great thermal stability and overall chemical inertness. Btw, what does 'arc' mean (couldn't find it)? Wkr Johan |
#33 | |
http://teslamania.delete.org/frames/...0kV_Switch.mpg Regards Charles |
#34 | |
The elements it consists of are very nasty. The plasma is hot indeed. S-F bonds arent incredibly strong (as F bounds go). The dielectric strength in power applications is sometimes increased by using N2 to pressurize it. SF6 dielectric strength is about three times that of air.
#35 |
But is the temperature in a closed bag, inside a closed or vented system, high enough to initiate this?
Wkr Johan |
#36 |
So one guy sais a gas thats lighter then air will make the internal volume seem bigger
another guy sais that a gas tahts heavier then air will make the internal volume of a box seem bigger, which is it?? if i go to the store and buy 20 baloons filled with helium, is it going to work? we all know we can realize huge dynamic peaks in bass in massive ported boxes, i want to put theese in a 5 cubic foot enclosure that has a 15 inch pa woofer in it. if anyone can help me decide if this will work, i'll have results withtin 3 or 4 hours
My 100$ (final cost) line arrays will blow you away |
#37 |
Maybe I'm just being cynical, but if you would go to all the work of deciding upon the optimal gas, figuring out a way to remove the air in the enclosure and replace it with said gas, seal off the enclosure completely, and be assured of no ill effects to the driver in order to get the enclosure to act like a bigger enclosure.....why not just build a bigger enclosure instead?
#38 |
good point,
one answer in my oppinion more bass, less space. very practical for DJ'ing and car audio
#39 | |
I think that the other guy says that in a gas that's heavier than air, sound will travel slower, which would be useful in the port of a ported box and in a tl. Somebody correct me if I'm wrong |
#40 |
The acoustic compliance of a box is
Ca=V/(rho0*c^2) for helium rho0=0.1785 kg/m3 and c=970 m/s, V is the box volume. This means that the compliance is 0.85 times that of an air filled box, that is it appears 0.85 times as big. In turn this means that the box would have to be 1/0.85=1.18 times larger to give the loudspeaker the same frequency response as the air filled box. On the other hand, since the velocity of sound is 970/345=2.8 times higher, all the box resonaces would occur at 2.8 times the frequencies of the air filled box. This is good. In the cases where standing waves is a problem, filling the box with helium could shift these frequencies to a region where they are less of a problem. However, I think that the main reason that helium is never used is that the gas will eventually leak out of the case, and then the dimensioning of the box will become completely wrong. And bass-reflex would be out of the question.
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 08:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 10:52 AM |
| build or buy | navin | Multi-Way | 9 | 16th November 2004 05:36 AM |
| Page generated in 0.10208 seconds (87.78% PHP - 12.22% MySQL) with 11 queries |
