Old 9th October 2005, 11:25 AM   #1
Send a message via MSN to noodle_snacks
Default Port Directly behind woofer
are there any problems that can arrise from having a port directly behind a woofer?
Old 9th October 2005, 11:37 AM   #2
pinkmouse's Avatar
You could get leakage of higher frequencies directly radiated from the back of the cone coming through the port, but that's all I can think of.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th October 2005, 11:01 PM   #3
If the port is too close to the woofer the resonace frequency of the port will change so the port has to shortened or lengthened accordingly.
Old 14th October 2005, 01:00 PM   #4
it is recommended that the inner end of the port is at least 1.5 port diameters away from the speaker cone, preferably more.
regards Andrew T.
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
Woofer and port position DragonMaster Multi-Way 2 13th September 2008 10:18 PM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
Need some help with sub woofer enclosure design port displacement boxman75 Multi-Way 1 20th August 2004 04:04 AM
Woofer fires directly into "board" eRiCdWoNg Subwoofers 0 19th April 2004 01:26 AM
Page generated in 0.07109 seconds (69.07% PHP - 30.93% MySQL) with 10 queries
