Old 5th October 2005, 02:23 PM   #1
jbandpc is offline jbandpc  United States
Default Maelstrom Dominance
Is it an error in my modeling or my interpretation of it, or does a 15" Maelstrom blow most everything else away (on paper)?
I modeled a 15" Tempest, Shive, Tumult, AE Speakers AV15, Bully-15, Dayton Titanic MKIII, RE Audio XXX15, in a 5 cubic foot sealed enclosure and the Maelstrom really stands out from the crowd in Extension and Group Delay. (Of course, it is more expensive than many of the others)
Thanks for your input,
Philip
Old 9th October 2005, 09:31 AM   #2
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
There is no magic sub - just expensive ones and cheap rubbish ones
Are you comparing them fairly?
Old 9th October 2005, 10:48 AM   #3
pinkmouse's Avatar
Comparing any drivers with just modelled results with TS data will tell you very little about real world performance.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 9th October 2005, 10:27 PM   #4
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
The Maelstrom performs better than the Tumult....? That wouldnt seem to make sense because the tumult is adire's top of the line driver while maelstrom is the 2nd.... Malelstrom also doesnt have XBL^2 it seems
The golden rule of DIY:
Build nice, or build twice!
Old 10th October 2005, 03:13 AM   #5
mike.e's Avatar
It will tell you the small signal performance - where most subwoofers spend most their time,as 115dB SPL always would surely drive you and the neighbours mad.
Im not debating the t/s vs listening issue.
Old 19th October 2005, 11:02 PM   #6
"Is it an error in my modeling or my interpretation of it, or does a 15" Maelstrom blow most everything else away (on paper)?"
What do you mean by "blows away"?
Unless it's higher max SPL due to xmax, I'd guess you made an error.
I've modeled dozens of drivers with T-S parameters all over the map in search of the most deep bass, and despite widely differing Fs, Vas, Qts, Mms, Cms, etc., and what I learned is that Hoffman's Iron Law holds sway - for the same power and box size, all the drivers converge to within a few dB of each other.
The "exception" is that you can get a lot more output from the same power and box size with a vented/PR design.
Noah
FS: 2x Maelstrom-X Subwoofers chrismercurio Swap Meet 0 2nd April 2009 07:33 PM
Distorsion on Maelstrom VS Tumult! Lazyworm Subwoofers 12 21st December 2004 06:25 PM
Will a maelstrom on 500w be as loud as a titanic on 1000? Fryguy Multi-Way 6 3rd September 2004 04:19 AM
Finished my Maelstrom Sonotube after almost a year of work kingdaddy Subwoofers 20 10th January 2004 11:03 PM
Adire Maelstrom $225usd/$349can seangoesbonk Multi-Way 0 31st January 2003 07:40 AM
Page generated in 0.08183 seconds (77.08% PHP - 22.92% MySQL) with 10 queries
