Old 4th October 2005, 09:19 PM   #1
boris333's Avatar
Default Subwoofer Wiring Diagram
i got 5 subs that are SVC they are 4 ohms now how do i wire this to like 1 or 2 ohms ?
Old 4th October 2005, 09:34 PM   #2
Speakerholic
Cal Weldon's Avatar
If you take four of the subs and wire them in parallel, it will give you a 1 ohm load. Is that what you are asking?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th October 2005, 09:37 PM   #3
boris333's Avatar
well like i said i got five subs so how do i do this then wire them all in parallel ? how many ohms will that be then with all five ( 5 ) subs ?
Old 4th October 2005, 09:53 PM   #4
Speakerholic
Cal Weldon's Avatar
I don't know how you would wire five subs and keep it above an ohm, that's why I told you about four.
EDIT: I should say I don't know how to divide the power equally and keep it above an ohm.
Old 4th October 2005, 09:59 PM   #5
boris333's Avatar
yes but i wont to use all five so like right now they are wired up all parallel to the amp it sound ok but the amp turns off somethimes like the amp is 1200 RMS and the subs are 1500 RMS in total so is this i good wireing option or is there others to try ? the amp is JBL 1200 so they say that it puts out like 1300 RMS
Old 4th October 2005, 10:01 PM   #6
Speakerholic
Cal Weldon's Avatar
wire four, keep one as a spare.
Old 4th October 2005, 10:03 PM   #7
boris333's Avatar
hmm i can't because then i ll have to make a differnet box and i will be pushing the subs to their limit
Old 4th October 2005, 10:24 PM   #8
Speakerholic
Cal Weldon's Avatar
how did you get into this mess?
What I'm asking is how on earth did you end up with 5 subs?
Old 4th October 2005, 10:39 PM   #9
boris333's Avatar
well i build the box for the 4 subs then i had this one extra sub so i decided to put it on the box since there was space on the box and i wouldn't have to push those 4 to their limit so ........
Old 4th October 2005, 10:50 PM   #10
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
power 2 of them and use the other 3 as passive radiators? as was said, using four in parallel is your best bet. five 4 ohm subs in parallel is 0.8ohms nominal (which will realistically appear almost like a short at the outputs of the amp) drawing a LOT of current and causing your amp's protection circuitry to kick in so it doesn't self destruct!
Please check my wiring diagram... eisenhower Multi-Way 13 16th October 2006 07:30 PM
wiring diagram for 4x12 guitar cab carlosy Multi-Way 1 2nd June 2006 02:31 AM
can i use this wiring diagram mitchell Car Audio 3 23rd August 2004 08:50 PM
Wiring diagram for S&B Tx102 TVC needed Peter Daniel Parts 5 10th October 2003 09:56 PM
Page generated in 0.09914 seconds (78.87% PHP - 21.13% MySQL) with 10 queries
