Old 13th September 2005, 08:23 AM   #1
croccodillo's Avatar
Default Hidden subwoofer
I'm planning to realise a subwoofer box for my sound system: my idea was to place the sub under my sofa, in manner to hide it.
The sofa is 2,5 m long, and almost 1 meter deep.
The big problem is that the free space under it is really low, about 16 cm (6.3").
I have two 8" and one 10" drivers, my idea is to use the two smallest ones in parallel, side by side, in a vented box.
So, in you opinion, a box so "flat", can work fine?
I made some calculation win WinISD and it should work down to 30 Hz, but I'm afraid its shape...
Ciao,
Giovanni
Old 13th September 2005, 11:14 AM   #2
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
Hi there Giovanni,
I recently built a very slim sub designed to sit against a wall. It would be just as happy under a sofa.
Its dimensions were: 90 litre 3.2cu.ft enclosure 1130H * 200D * 590W.
This is quite close to what you were considering, so you might like to have a look. There's more detail and pics at:
http://www.users.bigpond.com/bcolliso/slim-jim.htm
It had a single 10" driver, two 90mm side-firing ports and an 80w amp and performs quite well!
regards
Collo
Ports rule!
Old 13th September 2005, 12:38 PM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Collo..... you going to start to hide your subs now? That would be a task
Old 13th September 2005, 04:18 PM   #4
Hi, take a look at my HideAway TL sub in this thread
A "hidden" horn sub
Hi from Bjohannesen
Suggestions for hidden sub homebuilder Subwoofers 14 26th June 2009 09:01 AM
Hickok Photo History - hidden web gem! Zero Cool Tubes / Valves 0 28th June 2008 10:52 PM
Hidden clipping made visible. Netlist Digital Source 9 30th January 2006 07:11 AM
Awesome driver or hidden ****??? youyoung21147 Subwoofers 42 26th January 2006 11:33 PM
Page generated in 0.06399 seconds (76.77% PHP - 23.23% MySQL) with 11 queries
