Feasible to make a line-level 3rd-order infrasonic filter?
Old 11th September 2005, 08:49 PM   #1
noah katz is offline noah katz  United States
Default Feasible to make a line-level 3rd-order infrasonic filter?
Is it feasible to construct a line-level passive circuit consisting of three cascaded RC filters?
I guess the showstopper, if any, would be insertion loss.
The amp is a Crown K2 with 10Kohm input impedance.
Could someone tell me where to look for design formulae?
Background:
I have two ported subs using Avalanche 12, tuned to 18 Hz.
I have occasional bottoming on aggressive soundtracks, which I'd like to fix with a 3rd-order (is Bessel the recommended type?) HP filter at, say, 16 Hz.
Noah
Noah
Old 11th September 2005, 10:10 PM   #2
Tweeker is offline Tweeker  United States
Insertion loss will be very large, may need a preamp. You might try something like a second order high pass at say 20hz on such tracks instead.
PLLXO
Old 11th September 2005, 10:52 PM   #3
Thanks, Tweeker!
Looks good, 2nd order should be fine.
I guess I calculate the insertion loss by ignoring the caps and calculating the voltage divider affect?
Noah
Old 12th September 2005, 06:18 AM   #4
RC high pass filter is a nice little tool that might help you out.
Old 12th September 2005, 11:51 AM   #5
phase_accurate is offline phase_accurate
AFAIK the K2 already has a 3rd order HPF. If you are not afraid of tweaking that you could try to change its cutoff-frequency.
Charles
Old 12th September 2005, 09:23 PM   #6
Thanks for that new link, Tweeker.
That one doesn't have second order, and doesn't seem to account for the amp impedance the way the first one does.
Speaking of which, can I just use the 10K amp impedance as R2 and dispense with the extra resistor?
"AFAIK the K2 already has a 3rd order HPF. If you are not afraid of tweaking that you could try to change its cutoff-frequency."
Right, at 8 Hz, but it's a lot easier to add an outboard filter than to dig around in the amp.
Noah
Old 13th September 2005, 07:25 AM   #7
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
You cannot add a 3rd-order passive filter to that amp because the amp input impedance is quite low at 10k. Even 2nd-order would be a struggle. And you would need a strong source.
The filter will be very droopy and affect the passband.
You need to build an active filter, which will give far superior performance in all respects, and can be very small. I think I might have a pair of 3rd-order active filter PCBs lying around at home, or could find a layout
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 13th September 2005, 07:31 AM   #8
If you could you could do it on the first order filter also.
This second order filter is just a cascade of two first order filters. Use the equations from t-linespeakers.org or Art Ludwig.
To use the java tool, you need to add in the amp impedance, it lies in parallel with R2.
The Java tool aggrees with Richie, effect on passband and high insertion loss.
Old 13th September 2005, 07:46 AM   #9
On the bright side, they are cheap and easy to try.
Old 13th September 2005, 07:38 PM   #10
Tweeker,
"If you could you could do it on the first order filter also."
I don't understand.
Looking at the schematic for 2nd-order HP at t-linespeakers.org, the amp impedance can be merged with R2, but there's nothing directly in parallel with R1 to merge it with.
Richie00boy,
"The filter will be very droopy and affect the passband."
Yikes, if R1 = R2/10, doesn't that automatically make the insertion loss 20 dB?
But why can't R2 be, say, R2/4?
"I think I might have a pair of 3rd-order active filter PCBs lying around at home"
Sounds interesting. Does it include a PS, run off a wall wart, or ?
I just need one BTW.
You can email me details at noah.katz at lmco.com
Or is there something I can just buy ready to go?
Noah
Feasible to make a line-level 3rd-order infrasonic filter?Hide this!Advertise here!
line level high pass filter rbrockman Analog Line Level 3 13th December 2008 05:21 AM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
FS: Passive line level filter coils hifi Swap Meet 13 27th December 2006 10:13 AM
Line-Level Low-Pass Filter Design JustinAtGT Chip Amps 10 31st May 2006 08:48 AM
Line level notch filter Josephjcole Full Range 7 23rd June 2005 10:40 PM
Copyright ©1999-2017 diyAudio
