#121 |
"an Infinite baffle sub? that would be as close as possible to being flat from 10 to 40hz"
Assuming you mean w/o EQ, that's only if the cones are weighted to bring Fs down to below Fs. Otherwise a vented box will have lowest extension, in both FR and max SPL.
----------------------------------------- Noah |
#122 |
Yes, an IB sub should be about as flat as you can get at frequencies so low. Basically, if your talking really really huge enclosures, the sub is going to be pretty close to an IB. Granted, I have not built one, but have read about them extensively and am curious. I have built a sub flat to 15hz and I love it, but I am intrigued by the extreme extention of the IB
#123 |
"Yes, an IB sub should be about as flat as you can get at frequencies so low."
No, a vented design will always allow a given driver to go lower/louder. Less practical than IB, of course, because you need to have an actual box.
#124 | ||
I'm mostly certain that you guys are wrong about hearing damage following the Fletcher Munson or A-weighted curves. Damage is tied to intensity not frequency, AFAIK. The frequencies that are damaged may not be the frequencies that caused the damage, though. Check here: http://www.hearnet.com/at_risk/risk_...shtml#caraudio in particular, and the rest of this site for more info. |
| Subwoofer down to 10Hz and only 1 inch deep! | ashok | Subwoofers | 7 | 6th May 2009 04:36 AM |
| 40hz seems too much | Kelloggrice | Subwoofers | 7 | 29th March 2007 12:30 PM |
| Which BLH for linear response down to 40Hz? | Tyimo | Full Range | 72 | 22nd December 2005 08:23 PM |
| forum project 4932: make something that can do a good 140db at like 10hz | travis | Multi-Way | 28 | 21st February 2005 03:51 AM |
| 40hz horn modeled | mikee12345 | Multi-Way | 0 | 30th September 2003 05:45 AM |
| Page generated in 0.07649 seconds (73.67% PHP - 26.33% MySQL) with 11 queries |
