Precision devices
Precision devices
Old 20th December 2005, 12:42 PM   #101
phase_accurate is offline phase_accurate
And the question ist: How does it SOUND ?
Charles
Old 20th December 2005, 12:42 PM   #102
wuffer is offline wuffer  Denmark
Originally posted by paulspencer
wuffer, you can put an open baffle dipole in a corner as seen in Linkwitz site, but its not so good for the midrange. I've seen a corner dipole woofer under a oris horn which seemed an appropriate combination. Or you could use a sealed monopole 12" for mids and above on top of a corner dipole. 3 way makes sense to me for this kind of setup, with a sub below 40 Hz if desired.
thanks.. 40hz is low enough for me at the time.. i think
Old 21st December 2005, 02:33 AM   #103
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
wuffer if you do a search on this forum on corner dipole I think you should be able to find a picture of the speaker I was thinking of which has some Lambda 15" drivers in a corner dipole with an oris horn on top. It might be of interest.
Old 21st December 2005, 04:54 PM   #104
hooha is offline hooha  Canada
hooha's Avatar
Originally posted by Puggie
They aint cheap:
http://www.precision-devices.com/distributors.asp
428 in the uk!
At that price I'm sure they're flying off the shelves <end sarcasm>.
Sure look like nice units though. Thanks for the info.
Mark
Breaking speed records - http://www.mach5audio.com
Old 21st December 2005, 08:51 PM   #105
Puggie is offline Puggie  United Kingdom
I paid a lot less for mine but its a little scratchy on the in stroke! re-cones are reasonable though, once re-coned it will still have cost me less than half that of a new one. just a shame I can't get the 21" basket in the oven to powder coat it a nice new shiny colour
Old 21st December 2005, 09:28 PM   #106
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Precision devices
How seriously do you take this hobby Puggie? Buy a new oven!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 21st December 2005, 09:47 PM   #107
I fear that taking a 21" sub into Comet (highstreet electronics and white good chain, often staffed by poorly trained chimps) would probably get me sectioned, they were very unhelpful when I went in with a 15" alloy wheel to see which cheap oven it would fit into last time I went to buy a dirt cheap oven!
I also wasn't taken that seriously when I last bought a car, going round the showrooms with a pair of 16"wide and 9" deep asymetric horns and compression drivers, checking to see which cars I could get them under the dash of for my stereo install!
Old 21st December 2005, 10:04 PM   #108
pinkmouse's Avatar
Precision devices
Wuss!
BTW, reconing those PD devices is a dream, certainly on the 24"s, the packing needed for the voice coil spacing was exactly that of a piece of card from a fag packet folded into two. Coincidence? I wonder...
However, the relatively large gap does attract all sorts of rubbish, so it's well worth running a piece of folded over sticky tape around the inside of the VC gap, just to get any bits of stuff out, before you fit the new cone.
Old 22nd December 2005, 07:20 AM   #109
Geenius is offline Geenius  Netherlands
Geenius's Avatar
Charles
Well, the best of both worlds. It combines the depth of the closed box sub with the clarity of the U-frame. But at the same time that is also it's downside. It's neither flesh nor fish as we say in the Netherlands. It doesn't excel in either region, so I have decided to put the PD2150's in sealed enclosures and will be using 15" woofers on my open-baffle main speakers.
It still is an amazing sub, one of the best I have heard, but I want the best in everything!
Old 22nd December 2005, 08:27 AM   #110
I think you made the right decision.
Charles
Precision devicesHide this!Advertise here!
Precision Devices 12" woofers Defo Multi-Way 8 30th July 2009 01:05 AM
Precision devices...... Village Plank Multi-Way 10 14th December 2008 07:49 PM
Precision Devices PD.158 Xmax? buggsson Subwoofers 6 20th May 2008 06:55 AM
Precision Devices tinitus Multi-Way 1 8th January 2008 12:57 AM
Compact 15" sub - BMS or Precision Devices? DIAR Subwoofers 7 4th January 2007 04:06 PM
