I want to make my own folded horn subs to be used in outdoor party's.
I was thinking of copying EAW kF-940, EAW LA-400 or EAW DCS2 but if there's anything else that will fit to my application it'll be OK. Like I've said this is outdoor party's dance floor 45ftx45ft under tent. Thanks |
#2 |
#3 |
meant to post a reply to this yesterday but never got the chance
if you're wanting to go down the 12" route (and many say this is the key to good bass - small easily movable cone with high excursion creating a piston effect) then you can't go far wrong with the LAB Sub full details can be found on the prosound forum where it was born - http://srforums.prosoundweb.com/index.php/f/3/0 however i will warn you the woodworking is a b*tch, and they are best run upto 80Hz max with something like an HD15 above which brings me to the next site to look at www.speakerplans.com this site contains plans by Rog Mogale 18" & 15" horns plus bandpass boxes and mid tops there's also a forum there |
#4 | |
Norbert
They then use a thin veneer and fit it into the CNC groove, and damp it with a plastic foam. If you are you privy to details we are all ears |
#5 |
qi
Regarding KF-940 it sounds really complicated, however I'm a carpenter and I've done CNC routing before. But still it's a lot of work doing that box. I do have picture of 940 exposed and I was thinking of doing that ]cenventional way without CNC just using regular material and methods. It sounds like you know this box well, do you know where I can get more info, like detailed pictures and measurements? What about DCS2 sub? Can you compare it to KF-940? |
#6 |
What about horn subwoofer plans? I only saw one site www.spekerplans.com There's www.loudspeakerbuilder.com but they only make boxes not sell plans.
#7 | |
I am sincere in my request to know more about the insides of the KF-940. Whatever pictures / details you have would be appreciated. Have you seen the plans for the Jensen Imperial? While these plans have been "super-sized" for a 24" driver, you could scale them for a 12" by dividing everything by 2... |
#8 |
Here is the actual link to the super-sized plans...
http://www.steevee.com/jensen/jensen.htm Half-sized, they are about 4' x 3' x 2'. |
#9 | |
You can't scale horns this way, any more than you can a sealed or vented cab, unless of course you want Fl, Fh to be much higher. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#10 |
| dual folded horn plans | bacon665 | Subwoofers | 21 | 24th June 2009 03:45 AM |
| Peavey FH-2 FH2 FH1 FH-1 Folded Horn info X-Ray plans please! | Peavey MB1 MB-2 | Multi-Way | 0 | 6th February 2006 03:50 PM |
| Page generated in 0.10988 seconds (80.68% PHP - 19.32% MySQL) with 11 queries |
