Old 26th August 2005, 09:05 AM   #11
nniwelt is offline nniwelt  United States
I have looked for a long time to get this photo, cause I was wondering how this box is made. Eventually this image came from EAW promo materials.
*** Image removed at members request - Vikash
Old 26th August 2005, 11:09 AM   #12
qi is offline qi
Originally posted by GM
Greets!
You can't scale horns this way, any more than you can a sealed or vented cab, unless of course you want Fl, Fh to be much higher.
GM
Thanks for the clarification, Greg.
Use a scale factor of .625, not .5 to get the original Jensen Imperial dimensions. The original design uses a 15" driver, not a 12".
I see no image...
Old 26th August 2005, 01:05 PM   #13
GM is offline GM  United States
GM's Avatar
Greets!
One more time..... you can't scale a cab this way and expect similar performance! Anyway, Steve's design is enough different from the original that he shouldn't be referring to it as an 'Imperial' IMO: http://www.highefficiencyloudspeaker...l_Build-in.jpg
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th August 2005, 02:32 PM   #14
qi is offline qi
GM
Yes and no...
I am just using simple math to scale a "super-sized" design back to its original state.
The plans you posted are the originals, and known to be flawed and very difficult to work with.
Actually the website you reference confirms this.
Steve's plans are easier and more "buildable" IMO
Old 26th August 2005, 05:10 PM   #15
qi
You see image now?
Old 26th August 2005, 06:08 PM   #16
qi is offline qi
Norbert
Yes, thank you.
At a quick glance, it looks "doable". The expansion rate almost looks linear -- (consisting of expanding straight sides).
The two curved folds could be made of thin veneer, back-filled with "great stuff" (pvc foam) for rigidity and damping (essentially what they describe)
The initial flare is at a perpendicular plane to the main flare, but also appears to be linear (expanding straight sides)
It looks like a single driver may be an option, also.
But the thing is a monster (approx 5' x 3' x 3') -- not easily portable (unless you look like THE ROCK)
Old 29th August 2005, 04:43 AM   #17
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
Originally posted by qi
Norbert
Yes, thank you.
The eaw cabinet is simple.The fancy foam may help resonance of panels. The curvings wont help it in its passband.
The series of parabolic/conical expansions approximate an exponential or hyperbolic flare. Probably 4-8units required for stated sensitivity and cutoff.
Marketing ploys use a cover of mystical magic to make a unit appear advantagous to buy. Its probably similar to the labhorn. Easier to make too!!
dual folded horn plans bacon665 Subwoofers 21 24th June 2009 03:45 AM
Peavey FH-2 FH2 FH1 FH-1 Folded Horn info X-Ray plans please! Peavey MB1 MB-2 Multi-Way 0 6th February 2006 03:50 PM
Page generated in 0.08651 seconds (78.68% PHP - 21.32% MySQL) with 11 queries
