#11 |
10-4 Franz, i wonder too...
try your hand at fiberglassing over the mesh, instead of paper mache. buy the 'boat repair fiberglass' (and a box of latex gloves) and since you don't have a wife to offend with the smell, it'll work. it's much stronger than starch/flour/milk |
#12 |
Fiberglass is indeed good stuff, but I would worry about it affecting the sound significantly if you hide the speakers.
OTOH, if you make the speakers part of the statue (eyes and mouth?), that may not matter nearly as much. In addition to doing fiberglass sheets over a form (styrofoam), Don't forget that you can build mass with long fiberglass fibers mixed with whatever resin you'll choose. I'm assuming you'd choose polyester resin for this job; if that's the case, you can use Bondo-brand fiber glass filler from the autobody shop for that sort of stuff. Comes already mixed and ready to roll (just add hardner). Also, if you DO do this in glass, I can provide *some* additional guidance down the line. I've done lots of glass repair work (but no construction). Wes |
#13 |
Well to answer your question about the box size itself, the design that I started off with that I am taking all the measurements from I had done up some small models as shown here:
Original design That design combined with the matrix type of bracing ends up at about 11.5 ft^3. The box itself as long as I have done the calculations correctly should yield roughly 12.68 ft^3 before factoring in bracing, ports, driver volumes etc. This is by no means a square box I'm starting out with |
#14 |
The other thing is you could always have it rhino lined, or use undercoating. This way it doesn't matter if you spill, and it gives you a nice textured look
Josh |
#15 |
I would either hide the box or emphasise it. I'm about to build a subwoofer which is about 100 L (3 ft^3). I'm going to disguise it as a cabinet. Doors and handles are going to be the same as in the real cabins that I have in the room.
If I would wan't to emphasise the box I would probably paint it walldesign style and maybe continue the patterns to the walls: http://www.walldesign.se/ |
#16 | |
Not sure where I saw this, but paint the box black and add a cow pattern of chrome or reflective mirror material.
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
| FS: Large inductors, Large Ports, and Leaky Holes | luvdunhill | Swap Meet | 10 | 6th March 2009 03:01 PM |
| Looking for a Cover.... | TubeHead Johnny | Tubes / Valves | 0 | 11th January 2007 12:09 AM |
| Transformer Cover | TunaFish | Tubes / Valves | 3 | 16th March 2004 06:28 AM |
| Best way to cover a box?!?! | WhiteBoyChriss | Multi-Way | 27 | 10th November 2002 10:19 AM |
| Page generated in 0.10920 seconds (77.82% PHP - 22.18% MySQL) with 11 queries |
