Which Horn for linear response down to 20Hz? - Page 4 - diyAudio
Old 12th August 2005, 07:24 AM   #31
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
RCW : It isnt for the majority of laymen to decide that something is true simply because it seems to make sense,Id leave that to to the AES guys. But yes a BP4 does seem to approximate the horn below Fc. Have you seen the distortion measurements vs frequency here->
http://homepages.paradise.net.nz/sbk1/ssi.htm
Re DB keele,yes its true but if you cant afford multiple 18"s with appropriate EQ isntead of your single HT woofer on a massive horn its no use. (bearing in mind that we are talking HT not midbass)
You could just chuck the largest flare extender you can fit onto a labhorn size unit - FR can be worked out with hornresp.(single 18"/ 2 x 12"s or similar)
For HT I wouldnt have a cutoff any higher than 25hz or so. I wouldnt be expecting 16hz horn loaded.
http://www.speakerstore.nl/forum/viewtopic.php?t=121
8,8 meter basshorn "6090 Monster"
Old 12th August 2005, 07:49 AM   #32
rcw is offline rcw  Australia
Default re horns
I would expect no other reaction than that from someone who describes such observations as "bollocks" Brett, and then goes on to describe the sound of his horns in subjectivist aesthetic terms.
Perhaps in your case it is some sort of British understated aesthetic.
Old 12th August 2005, 12:20 PM   #33
Mark Kravchenko
mwmkravchenko's Avatar
Default What can and can't be done with horns
Small size and low frequency output together cannot be accomplished with a horn. THat's a statement we all have to agree is true.
The statements about output below Fs are convienient for the point at which they are measured. That is below Fs. Above Fs a horn will produce more volume with less power input than any other box configuration period. That is part of the allure!
The other part is it's dynamic range. Granted a huge bank of Vented sub monkey coffins can be coaxed into submission with enough kilowatts to become dynamic. I have both done it and heard it. Frightening! But the volume of the boxes and the cost of the rig driving them is not negligable.
But a smaller complement of drivers with power orders of magnitude lower will outperform the monkey coffins if they are coupled to a horn. ( horse coffin ) ( have to be fair to monkeys ) The trade off is the size. The design limited bandwidth to is a definite tradeoff. ( allthough there are definite design limits to reflex designs to ) But the realistic punch and apparent limitless power is very alluring.
As someone who spent a good many years playing in the back row of an orchestra. I say that hands down a horn portrays the reproduced sound with the greater realism.
Food for thought
MArk
Mark
www.kravchenko-audio.com
Old 12th August 2005, 04:07 PM   #34
Bull is offline Bull  United Kingdom
Default reply
http://www.geocities.com/loudspeaker...f_Bass_Bin.gif
This horn gets down to 28hz.
Old 12th August 2005, 04:42 PM   #35
Cortez is offline Cortez  Hungary
Cortez's Avatar
Default Re: What can and can't be done with horns
Well, it depends...
Lets take an infinite, open-air acoustical environment.
We have a cone, and we want to radiate sine soundwaves.
(The cone now just radiate in one direction for simplicity)
At a given frequency the efficiency of sound radiation depends
on the size of the cone. For a lower frequency a bigger cone
is ideal, cause a low freq sound means slow air-movements, and
therefore a lot of time to the air to escape far from the cone
in every direction. Therefore air will rather just move instead
of compression and pressure-variation (generating sound).
Increasing the frequency the radiation is getting even more directed,
cause for the air particulars its easier to radiate the sound in the
cone's axle, instead to propagate it all around the cone.
Now then, its clear that for great bass we need a cone as huge as possible.
But (and thats the point) in a closed place this work a bit different.
In this case we need more power to radiate, cause we must compress the air
in this place a bit. (The walls and the corners push back the waves...)
So there is an important thing, that peoples often forget:
Where do we want to achieve the bass improvements with our horn ?
Remark, that a BR enclosure can also help a lot in bass reproduction,
although it has just a little port. Now then, the are two extremity of
sound radiating:
- small area & big amplitude
- huge area & tiny amplitude
A panel-loudspeaker is rather the second type and a dynamic
speaker with coil and magnet is rather the first type.
With an average subwoofer speaker we have a finite power, and the speaker
alone can radiate low freqs with just a small efficiency.
Now with a horn we can make a transform between the two extremity above.
And we should do this too, cause in a closed air-space there is an optimum
horn-sizing for a given speaker. Not the horn with the biggest mouth is
definitely the optimum.
Old 12th August 2005, 06:37 PM   #36
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Again I ask, what is the consensus regarding a large chambered rear horn in order to achieve true subwoofer extension in a relatively compact horn size? It seems to work well in cabs like the Jensen Imperial.
Everyone has a photographic memory. It's just that most are out of film.
Old 12th August 2005, 09:21 PM   #37
Cortez's Avatar
What is the consensus ? Nothing. These are complex things,
specially at low freqs, e.g. the room plays a big role in this.
Otherwise what do you exactly ? There are a lot of sub-horn plans on the net.
Old 12th August 2005, 10:34 PM   #38
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
Why is it that I always hear RCW saying that a horn approximates a 4th order bandpass below the cutoff. What does a 4th order bandpass approximate below it's cutoff? A SEALED BOX!!!! why cant you just say a horn approximates a SEALED BOX below its cutoff!!!!
The golden rule of DIY:
Build nice, or build twice!
Old 12th August 2005, 11:00 PM   #39
Bass,
That's below the horn cutoff. The band pass cutoff can be much lower. This is also my point regarding using large chambered horns. For a sub all we need is a narrow bandwidth, eg 20hz to 80hz is just 2 octaves. If the lower end is really ported output with some loading, who cares as long as you get the extension.
Old 12th August 2005, 11:49 PM   #40
BassAwdyO's Avatar
it is indeed a very narrow bandwidth, I see your point john.
why dont we use rear chambered back horns? well for one I dont have any clue how to design a good one, for two, it's still huge, and well maybe it still has the same bass reflex sound to it, i dont know. I've never heard one....
Which BLH for linear response down to 40Hz? Tyimo Full Range 72 22nd December 2005 08:23 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Comments on bass horn sim in horn response paulspencer Subwoofers 38 1st November 2005 08:34 PM
Copyright 1999-2017 diyAudio
