Old 21st July 2005, 01:33 AM   #1
Send a message via AIM to Lyerigolfin Send a message via MSN to Lyerigolfin Send a message via Yahoo to Lyerigolfin
Question Very small sub to match satellites
Hello,
I'm looking to make a smallish sub (.5-1.25 cuft at the MOST) to match a pair of Adire KIT51s. I currently have a much much much bigger sub than I need for these speakers (atlas 15" in 4cuft sealed) and would like to make one that would fit under a desk like a conventional multimedia subwoofer.
My question is, what's the best driver to use? I can give it whatever power it needs, but I'd like to have one under 300W. I was looking at the TANG BAND W6-1139SC and it seemed pretty good to me. Also the Tang Band shielded 8" looked good. The only problem is the 8" sub in a ported box modeled with WinISD looks unsatisfactory. I haven't modeled up the W6 yet, I figured I would ask if anyone had any other suggestions before I did anymore modeling. The budget I'm working with is $25-75 per driver.
I'm looking for a conventional ported design, preferrably with 1 or 2 straight ports. I don't want a PR, sealed, or linkwitz transform circuit subwoofer either.
Thanks for the help.
Old 21st July 2005, 09:20 PM   #2
Try the 8" Dayton Quatro from Parts Express. Recommended enclosure volume .7 cu-ft.
Old 21st July 2005, 10:57 PM   #3
I've attached a plot of the quattro 8 vs the tangband 6.5. I like what I see with the 8" for sure, F3 of 35.96 and F6 of ~32. I'm just concerned that it won't get very loud; I think my KIT51s might overpower it. Anyone with an 8" ported sub have any comments on how loud they get?
Old 22nd July 2005, 01:08 AM   #4
Stocker is offline Stocker  United States
differences in amplifier gain or volume settings will compensate for differences in speaker efficiencies.
I am more and more impressed at the numbers folks get out of speakers these days. When I was a kid, this would have been pooh-poohed as science fiction / fantastic talk.
Keep it up engineers, and thank you God for the physics!
Jesus loves you.
Old 24th July 2005, 08:01 AM   #5
paulspencer's Avatar
I suggest you get the pro version of WinISD as this will tell you how much actual output you can get considering both thermal and xmax limited power handling. While you have similar results for the TB and the Dayton, what that doesn't show is how much actual output. As a quick guide for comparing speakers, however, look at VD which you can calculate by SD x one way xmax x 2.
I would say as a general rule of thumb, a pair of vented 8" drivers will keep most people happy. Their output will be roughly equivalent to an MTM with 6.5" midbass drivers. This is all assuming a typical 4mm xmax.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Satellites for new 5.1 system aramosfet Multi-Way 7 24th May 2012 08:39 PM
satellites+sub? testarossa2k Full Range 2 14th April 2007 03:30 PM
OB Satellites ralph-bway Multi-Way 2 21st November 2005 02:00 AM
Small(ish) DIY speaker to match GC?? monkey_zu Chip Amps 5 21st September 2004 02:25 PM
F3 for HT satellites dooper Multi-Way 3 7th February 2004 04:14 AM
Page generated in 0.09265 seconds (76.93% PHP - 23.07% MySQL) with 11 queries
