Need 10" TL driver--Seas 25F-EW or Peerless 850146??
Old 13th July 2005, 09:29 PM   #1
jjkozlow is offline jjkozlow  United States
Default Need 10" TL driver--Seas 25F-EW or Peerless 850146??
It's about a 6.4 cubic foot enclosure with 115" total line length. Any idea on which would work better here? Kind of need something 88-89dB (as these are) and 8 ohms (as these are) to match the satellites they'll go with. I have no idea on how to model them so as a "guess" which looks more suitable on paper? Any other 10" drivers with those parameters that are TL suitable?
Thanks!
Old 13th July 2005, 09:47 PM   #2
qwad is offline qwad  Australia
to start with the 2 that come to mind are: the peerless 850146, and the vifa m26wr-09-08 they both have qts around .32 so they would be ideal with nice smooth responses, allowing for simple x/overs and possibly two way with the right tweeters of the 2 l would say the peerless is the cheaper cheers and best regards, and good luck TC
we all have problems only some people have more than most....
long live the Magyar (Hungarians) in the world!
Old 13th July 2005, 09:57 PM   #3
Thanks, didn't see that Vifa one before. My sat uses the Vifa P17 woof so that one could be a good match.
Old 13th July 2005, 11:07 PM   #4
seanzozo is offline seanzozo  United States
Martin Kings TL and MLTL worksheets are the way to model them. Got to http://www.quarter-wave.com/.
Sean
Old 14th July 2005, 12:47 AM   #5
Thanks Sean, I've seen that site. Unfortunatly, I don't have the mad skills necessary (or patience) to learn MathCad on top of learning how to model a driver. That would take me months!!!
I'm not looking for "perfection" more for "something that has a proven track record for TL's" and would be suited for my basic specs mentioned above.
Old 14th July 2005, 06:06 AM   #6
Keep in mind that I have not used Martin's worksheets to actually produce anything (just to check some things I already have...so take this with a grain of salt)
When I run the TL you have with the Dayton RS270 ($63.50 at PE) and .2lbs/cuft stuffing I get:
about 10db down at 23-24hz
4db down at 30 hz
Flat from 40hz to 80hz
There is a suckout above this but since you aim to use it as a sub...no problem right
When I run the TL you have with the Peerless 850146 ($69.96 at PE) and slightly more stuffing (circa .25lb/cuft) I get ver similar results. flat between 80 and 40 with a slightly earlier but shallower roll off.
about 10db down at 22hz
4db down at 30hz
1db down at 40hz
When I run the TL you have with the Seas 25F-EW ($65.80 at Madisound) and similar stuffing I see
about 10db down at 24hz
5db down at 30hz
about 3db down at 40hz
I stuffed all of these lightly because you suggested use as a sub (I.e suckouts above 80hz wouldn be a problem) and you expressed a need for efficiency. All of these drivers seem to "work" in your TL, with the seas probably the least successful.
Tests performed at
http://206.13.113.199/ncdiyaudio/mar...fer%20test.htm
tend to suggest good performance for the Dayton.
The peerless has a much larger xmax spec than the Seas (9mm to 4mm) with the dayton in the middle at 6.6. How accurate these numbers are is probably debatable.
Sean
Old 14th July 2005, 12:29 PM   #7
Wow Sean, thanks a ton for taking the time to model those. Don't want to press my luck, but could you throw the Vifa M26wr into the spreadsheet to see what that yields?
I did not metion this, but, I am crossing to the sub at 100Hz so these suckouts your talking about, how bad are they above 80Hz? Was one of those drivers better then the other above 80Hz?
Also, any thoughts as to what's holding back the extension? I was told a 10" in that cabinet would go flat to 25Hz no problem. Maybe in-room response would yield greater extension? Would 12" drivers help any in my volume to get lower?
Thanks again!
Need 10" TL driver--Seas 25F-EW or Peerless 850146??Hide this!Advertise here!
New 8" Fullrange Driver by Seas gmilitano Full Range 8 22nd November 2007 02:32 PM
Peerless 850146 "replacement" 830668 fat_terry Multi-Way 13 24th January 2007 03:03 AM
Peerless India: Anyone need 12" subwoofer driver? yusuf Parts 0 10th January 2007 09:48 AM
Dayton RS270 vs. Peerless 850146 What should I do?? jjkozlow Subwoofers 4 23rd July 2005 02:50 AM
