I have two questions about pipe resonances.
1. I know they affect long ports, but what is the length:frequency ratio. I've read that a 30" port will create pipe resonances at about 220Hz or something like that. 2. When I asked someone at PE about pipe resonances, he answered that if I was worry about them, I sould dampen the ports. I'm not sure what he meant. Did he mean dampen the outside of the tube? I hope is not the inside or the dampening material might fly out. Thanks for all your help.
My DIY projects |
#2 | |
frugal-phile(tm)
dave PS: expect to get some ribbing for the use of "dampen" which means to get wet. Pouring water in your port will only make a mess
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Yes, he meant stuff the inside of the pipe. Just the right amount.
#4 |
what kind of damping should be used for it not to fly out of the port.
My DIY projects |
#5 |
Greets!
Ignoring any end correction calcs that gives a good approximation of the port's acoustic length (which will be longer), port resonances begin at ~ 2x its length, so ~13560"/2/30" = ~226Hz, though it will be a bit lower depending on the port's radius and how it's terminated at each end. Since it's classified as a 1/2WL open cylinder, it will have both even and odd harmonics. The best way to damp a port is to add a resistive cap over the exit, i.e. aperiodic loading. If you stuff the vent then you'll need to put a grill over it anyway in case it should be energized enough to pop it out. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 | |
frugal-phile(tm)
dave
#7 | |
Make less strong or intense. Reduce the amplitude of (a sound).
https://mrevil.asvachin.eu/ |
#8 |
Gradient uses a helmholtz resonator in the middle of the tube (pressure max point).
http://www.gradient.fi/design/highlights/ http://www.gradient.fi/products/intro/index.html |
#9 | |
frugal-phile(tm)
dave
#10 |
Do I have to stuff the whole port, or just part of it? Like for example half the length of the port.
Do I have to just cover the walls of the port or all the diameter? Will the stuffing change the tuning frequency? GM, Are there 6" resistive caps? where can I get them? Thanks you've all been very helpfull.
My DIY projects |
| Measuring resonances | pixpop | Analogue Source | 14 | 4th October 2006 02:43 PM |
| El-Pipe-O (El-Pipe-Mino) ??? | JDeV | Multi-Way | 21 | 26th October 2005 09:00 AM |
| Room resonances | Positron | Tubes / Valves | 28 | 12th December 2003 03:27 AM |
| Page generated in 0.16297 seconds (56.61% PHP - 43.39% MySQL) with 11 queries |
