#11 |
#12 |
Hi sorry to dig up an old post, but was wondering if anyone had any success with building one of the subs or similar using a pair of b139's?
I was thinking of giving the above link a go, as it seems to be a fairly easy and cheap construct and might be suitable for my small room. Any recommendation on measurements and wiring? If not I might just guesstimate. |
#13 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#14 |
I thought about doing one of those, but there a little too BIG for my allotted space.
How would you wire them? |
#15 | |
Here is an idea if you have measured similar T/S for two of your KeB139b drivers in an isobaric configuration: b
#16 | |
You might as well guestimate the dimensions, they are not critical. Wiring and c/o depends how you intend to drive them, 4 ohm plate amp ? rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#17 |
How much space have you got to play with? My design actaully models well (not bad for a1st attempt tapped horn that I just sketched out!) just need a clear weekend to build it
#18 | |
#19 | |
I'm not technically savy so it will be pretty basic and may not be optimum, but will give me something to muck around with......and one day when I know more I'll do something a bit better. What distance apart should they be? by the looks of the photos its around 4" |
#20 |
Well I went and built one (Dipol-Subwoofer mit KEF B139) out of 45mm ply, weighs a ton. Got it stuck in the only space I can find for now and have it hooked up to my Teac set on mono and the bass up and treb down until I can work out how to wire it up better.
Sorry for the lousy photo will post up a better one if anyone's interested. Any advise on how to wire it would be appreciated, sorry I'm not tech savvy so you'll have to dumb it down for me . |
| KEF b139 sp1212 data? | Tomac | Multi-Way | 3 | 22nd December 2007 06:13 AM |
| building speakers with kef b139 | freo | Multi-Way | 29 | 7th February 2007 07:10 PM |
| KEF B139 for sub woofer | kennyb | Subwoofers | 3 | 7th January 2004 10:45 AM |
| Kef B139 ... | TugaTweaker | Swap Meet | 0 | 3rd January 2004 10:22 PM |
