Building my first 4th order BP box, any suggestions?
Old 21st May 2005, 10:00 PM   #1
theCat is offline theCat  Argentina
Default Building my first 4th order BP box, any suggestions?
I am building my first BP box to use in my HT setup. I am using a 12 inch car audio driver (audiopipe tsv12), I ran it on Winsid and the curve is the following. Do you think it will sound nice on a home setup? I plan on crossing it at 70 hz, but I am afraid of "one tone bass". Any suggestions?
Thanks in advance!
Old 21st May 2005, 10:28 PM   #2
simon5 is offline simon5  Canada
With a bandpass like this, you'll only get output from about 40 Hz to 60 Hz... I think you can do better, unless you're looking at high SPL only.
DIYaudio for President !
Old 22nd May 2005, 08:10 AM   #3
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Default Re: Building my first 4th order BP box, any suggestions?
Originally posted by theCat
Any suggestions?
Yes. Don't build a bandpass box.
Old 22nd May 2005, 05:23 PM   #4
Haha hard answer!
Thing is, WinISD suggests either a sealed or 4th order BP due to high EBP, so that´s why I am going for that design........
Old 23rd May 2005, 12:50 AM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I'm with grumpy Bill. I've never heard a bandpass sound good anywhere but in a car.
Not natural sounding
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd May 2005, 01:06 AM   #6
RJ is offline RJ  United States
The sound quality of a 4th order bandpass isn't that great.
For kick a** bass I recommend a dual-chambered bass reflex;
http://www.diysubwoofers.org/prt/dual_chamber.htm
Old 23rd May 2005, 07:26 AM   #7
These are the specs of the speaker:
QTS 0,56
QMS 3,85
VAS 54,4 L
QES 0,62
FS 33hz
SPL 88 db
RE 2x4 ohm
PE 300 w
Le 1,85
Xmax 8,0
Does anyone think it can work on a ported box?
Old 23rd May 2005, 07:59 AM   #8
Yes, it can always work in a ported box, I never look at the EBP number.
You could tune it around 20-25 Hz I guess.
Old 23rd May 2005, 05:01 PM   #9
I get 24 hz. F3 & Fb
Box size 13wx24hx22d
Port 3" x 19 1/4"
At 24" high the board that seperates the two chambers would be 8"
So the small chamber would be 8" the large chamber would be 16".
Power rating before Xmax & Port Chuffing is 150 watts.
Both at 25 hz.
Total box volume is 87 litres.
Yes, It's Do-Able!!!
Building my first 4th order BP box, any suggestions?Hide this!Advertise here!
Gainclone building contest details (from BrianGT group order) BrianGT Chip Amps 299 26th April 2006 08:15 AM
Suggestions for 4th order bandpass, Peerless cones MASS Multi-Way 0 22nd May 2003 11:00 AM
Copyright ©1999-2017 diyAudio
