Old 18th May 2005, 04:05 AM   #11
RJ is offline RJ  United States
Doubling the ports more than doubles the length.
If the box is big enogh it might not be a problem.
Old 18th May 2005, 04:43 AM   #12
I can't see any reason you cannot design for six ports instead of 3. Howevr, if it is port volume you are after, why not just make 3 ports of a larger diameter?
Remember, in any kind of reflex box-the ports do not count as part of the box volume. The volume of the ports, theoretically, should be subtracted from the total box volume in your calculations. Most of the time the ports consititute fairly negligible loss of box volume, so we can ignore this. But if the ports start occupying 15% or more of the total box volume....
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 18th May 2005, 12:40 PM   #13
elambert's Avatar
I do understand about the port volume being added to total internal volume of the box. With the last box that is why I went with an external port. Fitting 3 4" ports inside the box was a bit tricky, plus I kind of liked the odd look of the external ports.
Dual Chamber Speaker Box suministros Multi-Way 17 20th May 2010 12:23 AM
Dual Chamber Reflex Subwoofer Revisited Hezz Subwoofers 14 26th February 2006 03:24 AM
How to model a dual chamber ported(Weems) enclosure in WinISD? Please help >> beady Subwoofers 4 5th August 2004 10:14 PM
Help on Dual Chamber Reflex box & car audio response Q's please (LONG) beady Multi-Way 0 3rd August 2004 11:09 PM
Dual-Chamber Vented Boxes BAM Multi-Way 9 2nd July 2004 02:37 PM
Page generated in 0.08684 seconds (68.45% PHP - 31.55% MySQL) with 10 queries
