this one is something to think about...
I mounted an accelerometer on a woofer (Adire DPL12, sealed enclosure), and measured the input voltage on the voice coil and the output voltage from the accelerometer. If I calculate 20*log(output/input), I get the dB SPL curve with an offset. This should be theoretically correct I guess. Now here comes the problem. I've measured the response in 200 different frequencies, and made a plot in Excel. I have a very nice 'peak' between 40 and 100Hz, as I expected (box too small). To be more precise: Qtc = 0.35 (0.4 according to datasheet, measured 0.35). Box = 50 liters. 'Peak' = 5.5dB, which mathematically results in a Qtc = 1.81. Since I know Qtc, Qts, Vb, I can calculate Vas. Turns out Vas is 1420 liter, according to the datasheet this should be 149 liter. What is wrong? It is not a measurement error (200 frequencies, very smooth curve), it is a method error. I just can't figure out what it is. Voice coil series/parallel connection doesn't matter, I already tried that. I also used a DMM instead of a scope, and vice versa. It always turns out the same. Funny thing is I've used the same method on a different woofer in the past, which resulted in a Vas that was close to the datasheet value (less that 20% deviation). Any suggestions are welcome. |
#2 |
maybe you got an extra zero somewhere.... 142 wouldnt be a bad measure. What is the equation you are using?
what are your values for Qts and Qtc?
The golden rule of DIY: Build nice, or build twice! |
| Capacitor tolerance | boxerboxer | Tubes / Valves | 18 | 31st May 2009 03:40 AM |
| DC-DC converter ...wiring and tolerance? | VvvvvV | Parts | 5 | 23rd January 2008 05:38 PM |
| Capacitors Voltage Tolerance | aud1out | Everything Else | 6 | 28th May 2007 07:29 PM |
| RN65C / E 10KB - what tolerance ? | Bernhard | Parts | 1 | 21st April 2007 10:10 PM |
| 0.01% tolerance 10 and 100 ohm resistors | SkinnyBoy | Swap Meet | 2 | 26th November 2003 11:38 AM |
| Page generated in 0.07330 seconds (67.05% PHP - 32.95% MySQL) with 10 queries |
