4x isobaric
4x isobaric
Old 16th May 2005, 07:06 PM   #41
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Jennice,
In your drawing above, just flip the outer driver around to clamshell with the inner driver, but retain the same depth so the outer driver's magnet is parallel with the cab edge. Yes it wastes some volume, but when covered by grillcloth you've got your SAF covered (no basket hanging out of the box), you get optimum isobarik coupling, and push/pull operation.
Everyone has a photographic memory. It's just that most are out of film.
Old 17th May 2005, 05:48 AM   #42
Jennice is offline Jennice  Denmark
Hi Dave,
Thanks for your replies. It's great to get input from someone more experienced with this.
I don't like the thought of high order filters, as like the KISS principle... So I guess I should try to cross lower then that, and use the Peerless HDS164 for mids (in stead of the HDS134 PPB), which I think will run out of linear excursion at high levels if it needs to go 180-200Hz before rolling off.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 17th May 2005, 07:42 AM   #43
Forgot...
The HDS134 has a linear X-max of 3,5mm
Jennice
4x isobaricHide this!Advertise here!
isobaric keyser Subwoofers 9 9th December 2010 01:35 AM
isobaric any info on how? newfinish Multi-Way 38 18th January 2008 02:04 AM
isobaric damping.. ChesterFuzzin' Subwoofers 9 4th January 2006 12:30 AM
isobaric resonator? tade Subwoofers 6 17th August 2005 07:24 AM
Isobaric for subs only? speekergeek Multi-Way 8 13th January 2004 03:15 AM
