Any experience with DB Drive subs ? - diyAudio
Old 3rd May 2005, 06:54 PM   #1
Default Any experience with DB Drive subs ?
I need 4- 12" subs for a pair of dipole cabinets that I have built.
These DB Drive units look interesting and have about the right Qts
I only hesitate cause they are advertised as car subs and I have not seen much in this or other HT forums about this brand.
DB DRIVE PL12D4 Platinum Series ...
Features:
· Dual 2ohm Voice Coils/Dual 4 Ohm Voice Coils
· 180oz. Strontium (SR) Magnet
· Rubber Boot Design
· 3" Diameter High Temperature 4 Layer Voice Coil
· Extreme Excursion Motor Structure and Suspension
· Multilayer Treated Paper Cone
· Layered UV Treated Foam Surround
· Dual Spider Linear Design
· Black Textured Anti-Resonance
· Die-casT Aluminum Basket
· Integrated Tinsel Leads for High Excursion
· Push Button Terminals
DB DRIVE DBDPL12D4
Fs is 25 and Qts is .63 and xmax is .79 inches accordring to manufacturer site.
JM
Old 3rd May 2005, 07:55 PM   #2
here's a picture
Old 3rd May 2005, 10:04 PM   #3
Tweeker is offline Tweeker  United States
Have you considered the Atlas 12, it offers qts to .52, 23hz fs, xbl2, and bottomless motor. Is also well proven and not alot more expensive. The Atlas is more efficient, you can use series resistance to bring qts up still further.
That DB drive woofer looks to be designed for pounding out spl, 1500w power handing isnt needed in a dipole. Inductance on the DB Drive motor is 8 times that of the Atlas.
Old 3rd May 2005, 10:20 PM   #4
Can you explain to me the implications of that big diff in inductance.
I have seen Le mentioned before, and thought it only affected the higher frequencies like in midrange drivers.
Old 4th May 2005, 12:01 PM   #5
It has better transient response. I hate to use this term, but its "faster".
Old 4th May 2005, 04:38 PM   #6
Several people have used the 15" version for IB subs and they work well.
Given the blow out pricing for the Ascendent audio drivers those should be considered.
Something else to consider is the 12" TC-Sounds TC2+ Those have the lowest distortion we've measured in a 12". I use them in my dipoles and they sound very good.
Old 4th May 2005, 06:40 PM   #7
At $100 a piece the Ascendent audio drivers seem like a no-brainer.
Are they shipping these or is there a waiting list?
Old 4th May 2005, 06:49 PM   #8
No waiting list, ship in less than a week, but youd better call soon as they arent going to last long.
Old 5th May 2005, 04:58 PM   #9
OK ordered 4 Atlas 12 and can't wait !!
Does anyone know how high in frequency these Atlas 12 can be used.
With the light cone and low Le, I would think they could be run up to 250 hz easily unless there is a cone breakup mode.
I might be using these Atlas 12 with a Fostex fullrange driver on an open baffle and would need to crossover in that range.
Old 5th May 2005, 09:22 PM   #10
At .52 qts the drivers still making over 87dB at 250 cycles. It has an epoxied paper cone. I dont see how you could have a problem with anything but possibly a first order cross.
Personal experience, Which subs hold up the best skooter Car Audio 0 23rd November 2008 04:39 PM
Anyone have any experience with the LAT subs? JCoffey Subwoofers 3 4th June 2008 11:58 AM
DB Drive WD subs mojaras15 Car Audio 0 2nd May 2006 07:30 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 01:44 AM
Pro-amp to drive pair of subs Al Garay Subwoofers 2 20th July 2004 04:27 AM
Copyright 1999-2017 diyAudio
