Looking for very good bass driver - Page 2 - diyAudio
Old 1st September 2002, 03:47 AM   #11
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Slice,
Here is a very comprehensive list of speaker manufacturer links.
http://members.chello.se/jpo/driveunits.html
Below is a picture of one of my endtable subwoofers. They're 4.5cu.ft and the speakers are TAD 1601a's (about $500USD/pr. on eBay). They are tuned over damped with an electronic boost for a theoretical flat response to about 22Hz.
Enjoy
Rodd Yamas***a
Old 1st September 2002, 05:26 AM   #12
The blueprint 1803 looks like a great snag for $279.
Old 1st September 2002, 01:49 PM   #13
Wizard of Kelts
Just thought that I would mention that 2 ten inchers have the same cone area as one fifteen incher. So if you want to move the same amount of air as a fifteen incher but don't want a fifteen, that is one way to go.
Two twelve inchers have just a little less air moving ability than one eighteen incher.
One more thing. If you have two speakers and run them on different channels of the amp, the sensitivity goes up 6 dB. So if you have one ten inch woofer that plays at 90 dB on one watt input, then doubling the enclosure volume and adding a second ten incher connected to a different channel playing at one watt will make the setup play at 96 dB. (of course you want to adjust the port length).
Old 1st September 2002, 05:18 PM   #14
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
why is that true.. why wouldent you just put them in paralle and get 4 ohm speakers and drive them like that.. im thinkin about 4 10's 2 x 10" per box then have my small eithere towers or small satelite speakers. on top..
Old 1st September 2002, 05:35 PM   #15
frugal-phile(tm)
planet10's Avatar
1/Many amps (most actually) don't really like 4 ohm loads.
2/ if your stereo amp doesn't bridge into mono, it is a way of getting both channels in play (again much more conservatively -- both channels see 8 ohms instead of the 2 ohms they would see with the amp bridged driving a 4 ohm speaker)
A BIG possible advantage of 2 drivers is that can be loaded push-push. The pus-push combination cancels most of the Newtonian load generated by a moving speaker and thereby it is not passed on to the box, making the box work & sound better.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st September 2002, 05:39 PM   #16
Banned
so having them move in the same direction or odd even per driver in per box.. ill be startig theis project soon and takeing all this info down ( via printer of course ) hehe and building them ported since ported is low and loud and alows the drivers to breath..
Old 1st September 2002, 08:06 PM   #17
--Two twelve inchers have just a little less air moving ability than
--one eighteen incher.
Wouldn't you have to overdrive the 12's to get the same
low freq. output as the 18" playing a modest volume?
If you over drive 12's to get the same results, won't
distortion increase alot compared to the 18" playing a
modest volume ?
If an array of 12's is better, why do prosound folks
use arrays of 18's ? hehe
Old 1st September 2002, 08:11 PM   #18
frugal-phile(tm)
planet10's Avatar
Efficiency.
dave
Old 1st September 2002, 08:14 PM   #19
Banned
i agree to that one.. my amp will be running in 4 ohms powering 2 x 10" subs. per side..
Old 1st September 2002, 08:45 PM   #20
frugal-phile(tm)
planet10's Avatar
both drivers pushing the box together
Concept woofer
an implementation
bipole concept
bipole implementation
dipole concept
dave
PA bass driver a007udio Multi-Way 6 31st May 2006 11:06 AM
bass amp and driver leander Solid State 4 3rd November 2005 12:53 PM
Looking for a good 6.5" mid bass cody6766 Multi-Way 4 30th September 2004 01:06 AM
Bass Tubes are they any good??? Bull Car Audio 1 13th April 2004 05:41 PM
Getting the most bass out of a driver BAM Multi-Way 7 5th September 2002 04:43 AM
Copyright 1999-2017 diyAudio
