Old 21st April 2005, 12:15 PM   #31
bri1270 is offline bri1270  United States
That's a configuration I was thinking about also...that might work out, but I could be closing in on my center speaker which is mounted on the wall. More measuring.
According to this http://www.bcae1.com/
seires/parallel keeps the ohms the same, so why not go with 8ohms, wouldn't they be "easier" to drive?
Old 21st April 2005, 12:30 PM   #32
Tweeker is offline Tweeker  United States
Its easier on them amp, runs cooler etc, but the 1,000 watt plate amp from PE only gives 512watts at 8 ohms.
Old 21st April 2005, 04:13 PM   #33
Duh - I guess I should have looked at the specs...thanks
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.07644 seconds (63.09% PHP - 36.91% MySQL) with 10 queries
