Old 15th April 2005, 07:01 PM   #1
Default subwoofer help
i just build a sub using a vifa ma26wr0904 in a 1.5cuft sealed box as suggested.my problem is that the voice coil hits the back plate easyly and make a very noticeable noise.what can i do about this?will a smaller box help?by the way the box is sealed very tight with alot of bracing.the woofer seams to move to much for the power i'm using.
thanks
Old 17th April 2005, 02:20 AM   #2
simon5 is offline simon5  Canada
You could go ported, which will bring that problem lower in the frequency band, or use a smaller box. The smaller box will probably be boomy, it depends on what you want.
You're asking too much for this driver I guess.
DIYaudio for President !
Old 18th April 2005, 01:49 AM   #3
this woofer is designed for closed box only.the voice coil is hitting the back plate at moderate volumes.my question is will making the box smaller stop the voice coil from hitting.
Old 18th April 2005, 02:32 AM   #4
Ron E is offline Ron E  United States
Ron E's Avatar
Different people have different ideas of moderate volumes.
A smaller box will reduce excursion, increase power required to bottom and reduce bass response somewhat. In your case, dropping volume by half (21liters or 3/4 cubic feet) should increase power to bottom by almost three times. EVen so an amp capable of 200W into 4 ohms should probably be able to bottom it. If you want more SPL, you need more woofers or woofers with longer excursion
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 18th April 2005, 02:33 AM   #5
planet10's Avatar
Default Re: subwoofer help
vifa ma26wr0904
I couldn't find that driver on VIFA's site.... do you have any data on it?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th April 2005, 06:48 PM   #6
hers the tread where i found the sub
Vifa subwoofer
glen
subwoofer under bed Potato42 Subwoofers 7 13th January 2009 03:21 PM
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 04:59 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 11:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 04:51 AM
Page generated in 0.07203 seconds (82.76% PHP - 17.24% MySQL) with 10 queries
