Old 14th April 2005, 11:00 PM   #21
ya im sorry. i was reffering to the 85L box. but im gonna try to cut as close as possible to an straight edge. i thought that if its not staright, it would effect the frequency or sound output. other than that ive got everything staright forward. i only need to buy couple tools and i should be ok.
finsih, i think im gonna go with veneer because it looks easier. and atlas is final i think for the driver. im gonna start everything start of next month.
Old 14th April 2005, 11:20 PM   #22
mateo88 is offline mateo88  United States
I'm not sure if you're a noob when it comes to woodworking or not (sorry if you aren't), but using a guideboard makes it easy to do straight cuts with a jigsaw. Just nail a straight board along the line of your cut using finishing nails, and saw down that.
Again, sorry if you already knew this, but it actually took me longer than I would have liked to figure this out.
Old 15th April 2005, 01:04 AM   #23
Raoul is offline Raoul  United States
Good suggestion about the jigsaw guide.
I've been running some simulations on WinISD. I wasn't so sure about the Atlas 12 at first, as Shiva was showing better response curves in the EBS box. However, the mid-Qts option (short the gold terminals with 1.5ohm resistor) is producing some nice results.
Old 15th April 2005, 02:08 AM   #24
what do you mean Raoul? short which terminals?
Old 15th April 2005, 11:05 AM   #25
http://www.ascendantaudio.com/Atlas%...-S%20specs.htm
See the bottom of the page.
Old 15th April 2005, 07:15 PM   #26
aahhh i got ya. it says 1.5 ohm resistor but how many watts does the resistor need to be?
Old 16th April 2005, 10:24 AM   #27
A five watter should do. There are some tradoe-offs in power handling and efficiency, though. Here is a link to an article describing the operation:
http://www.adireaudio.com/Files/Tech...OOperation.pdf
Old 16th April 2005, 02:26 PM   #28
Brett's Avatar
Jigga, once you decide on a box design, draw it all up on a piece of paper to make a 'cut sheet' showing how you're going to cut all of the pieces from the 8x4 or 5x5 and take it to a cabinetmaker/kitchen place and have them cut all of the pieces to size for you on a large saw table. You'll get MUCH more accurate results and it will only cost a modest amount and save a ton of time and hassle. Think about how to do it carefully and explain to the guy doing the cutting what you actually want to do with all the panels and let him wrk out the logistics of the cutting. For example, all 4 sides of a stereo pair could be rough cut, then finally dimensioned on the saw all at once, so they're all the same size. Ring around in the yellowpages in your area and ask if they'll do it and how much it'll cost for a cash job.
Old 16th April 2005, 05:38 PM   #29
Raoul, i think ill with standard 5w 1.5 ohm resistor just to be on the safe side.
Brett, thats some nice suggestions. ya i already laid out the cut out on a sheet and i can get all of the wood required from a 8'x4' sheet of MDF. ill try to get it cut at home depot.
Old 16th April 2005, 08:58 PM   #30
It looks like a 39cm long, 10.20cm diameter tube gives a better response with the Atlas 12. 45cm looks even better (lower group delay) but might introduce port turbulance. You will have to adjust the length for the flared ends.
Watch out for cuts at Home Depot. If the dimensions aren't correct the whole box will be off. As Brett said, it can be a real headache.
To simon5 (or others): You seem pretty familar with WinISD, is there a feature that warns of audible vent noise?
Need help designing HPF add-on shaaregeulah Solid State 0 2nd May 2008 05:35 PM
Help designing a new set-up. djames03 Car Audio 4 12th May 2006 03:32 PM
Help please, designing a TL sub ShinOBIWAN Subwoofers 12 1st July 2004 04:14 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
This is the DAC which I`m designing purer Digital Source 12 26th July 2003 01:56 AM
Page generated in 0.10267 seconds (79.18% PHP - 20.82% MySQL) with 11 queries
