Old 14th April 2005, 12:17 PM   #21
Puggie is offline Puggie  United Kingdom
To be honest I'm looking at the 15" Volt not the XXX now, basically from my playing it looks a more suitable sub (and I've found one I can 'borrow' for testing). I havn't had chance to measure up yet but the car does look smaller than I first anticipated
Old 14th April 2005, 12:40 PM   #22
Good choice Luckily still the same rules apply.
In that case let's wait till you do.
Mvg Johan
Old 17th April 2005, 03:46 PM   #23
Right, my friend is being pathetic and wants to keep his rear seats, so for now we have this ammount of space to play with:
Height 30" (762mm)
Width 43" (1092mm) the width at the top is the same as between the wheel arches
Depth 43" (1092mm)
Once I have finished beating the idea that loosing the back seats is a good thing, I think we should have about 20" more depth to play with.
For subs, the amp we have is happy doing 2 X 1000Watts RMS into 2Ohm, it will give about 20% more than this with the alternator running as its unregulated. because of this I'm looking at either a single Volt R3853 which is 4 ohm so bridge the amp and give it 2000w (I'm pretty confident they can take this power as a friend of mine runs this kind of power to RV3823s in his PA rig) Or use the RV3823 which is only available as an 8Ohm driver, but we could parallel 2 of them, is there room to do this, this would give more cone area and better powerhandling?
R3853
Nominal Diameter 381 mm
Power Capacity 300 watts
Sensitivity 93 dB/watt/m
Frequency Range 30-500 Hz
Impedance 4/8/16 ohms
Bl Factor 19 N/A
Voice Coil Diameter 75 mm
Voice Coil Material Copper
Maximum Excursion 28 mm (before damage)
Fs 32 Hz
Re 7 ohms
Qa 3.25
Qe 0.44
Qt 0.39
Vas 172 litres
Xmax 5.5 mm
Sd 734 cm2
Vd 600 cm3
Le 1.2 mH
R3823
Nominal Diameter 380 mm
Power Capacity 500 watts
Sensitivity 96 dB/watt/m
Impedance 8/16 ohms
Bl Factor 19 N/A
Fs 39 Hz
Re 5.4 ohms
Qa 3.25
Qe 0.35
Qt 0.32
Vas 133 litres
Xmax 4.5 mm
Sd 755 cm2
Vd 340 cm3
Le 0.9 mH
Old 17th April 2005, 11:08 PM   #24
Send a message via AIM to CBFryman
if you end up not doing it i am willing to take that beauty of a 18" driver off of your hands for you... make me an offer...
Old 18th April 2005, 02:45 AM   #25
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
Two 15" drivers on the horn?Very hard to fit+large rear chambers occur.
Consider two routes
-Scoop
-front loaded,rear sealed horn
with that size a horn is certainly possible.Its just a question of cutoff and sensitivity vs cutoff.
Xmax is still listed quite low...it wont matter for music at sane levels.
Old 18th April 2005, 09:24 AM   #26
CBFryman, postage would be a bitch from the UK
Mike.e
Right please explain in VERY BASIC TERMS what I can do with a single 15" as it looks like twin 15s will be too much. The Xmax is low but they are a lot more linear that the figures suggest, they can be run to 20-25mm excursion for extended periods, no problem and still sound very good.
Front loaded rear sealed, sounds to me like a basic sealed box with the sub firing into a horn.
Scoop, your've lost me but I'm thinking something like the PA Cabs which have a folded horn at the top and the mouth looks like a bucket scoop.
You say its a matter of Cutoff (as low as realistically possible) and sensetivity Vs Cutoff (how does this work then).
Old 19th April 2005, 12:43 PM   #27
I think your 1000w/2R amp is already bridged. You can only bridge once.
That is some alternator in the car, 3kW (1.5 times 1000w times 2) is about 4 times more powerful than normal car alternators.
regards Andrew T.
Old 19th April 2005, 03:26 PM   #28
Nope the amp is a stereo AB, rated at 2X1000W RMS into 2Ohm, that is about what it puts out from an 10.5V supply, at 12.5V we measured 1248Watts RMS per channel, and it keeps going up almost linearly to 15.5V if you can keep the voltage up, the amp is barely 60% efficient so if you do the math you get an idea of the current draw and why keeping the voltage up is such a mission. it is rated as stable at 4Ohms bridged but will run at 2ohm bridged if you can keep it cool enough and if you can keep the voltage up near 14V then it will do 3kW bridged
It is a beast of an amp: US Amps 2000X which is the predecessor to the AX2000. www.usamps.com.
I've given up on a big enough alternator, just running with a couple of 110Ah batteries about 6" from the amp.
Old 21st April 2005, 02:25 AM   #29
mike.e's Avatar
Puggie: it takes alot of detailed writing!
You MUST read these links first
http://www.diyaudio.com/wiki/index.php?page=basshorn
http://www.volvotreter.de/ ->Downloads -> Dinsdale horn files/edgar horn files
A scoop is a horn where only one side of the cone is loaded,the rear is un enclosed. Theirs nothing too wrong about this apart from asymmetrical loading,causing 2nd harmonic distortion. Most commercial basshorns dont do this. However,if people are used to hearing reggae through scoops with this distortion,people will like the sound:d
Okay so now post the t/s specs of the woofer youl use.
What was the dimensions[max] again?
State what sort of music etc
And what is your aim
Then I can help with modeling,and CADing up the horn.
Cheers
Speaker Designing Software morfius Multi-Way 4 13th September 2007 06:01 AM
Designing software Twisted85 Multi-Way 2 3rd January 2007 06:29 PM
Help with speaker designing software for JBL project ebarker2 Multi-Way 1 26th May 2005 01:14 AM
CAD Software For Designing Amps barroter Everything Else 3 1st November 2003 01:09 AM
Subwoofer box designing software palesha Subwoofers 2 4th November 2002 08:10 AM
Page generated in 0.14157 seconds (74.64% PHP - 25.36% MySQL) with 10 queries
