#21 |
Well now I am confused. When I put my power rating in the velocity goes through the roof literally. It's off the ******* scale. See image
http://img.photobucket.com/albums/v1...irvelocity.jpg I have also uploaded a new graph from WinISD pro seen here. http://img.photobucket.com/albums/v1...01/Pro32in.jpg The gray is the new graph and purple the old. |
#22 |
Your graph is showing ft/second instead of meters/second. The 53.8 ft/s that you are seeing at 16Hz translates to 16.4 m/s which is perfectly acceptable.
You should also look at your cone excursion graph with the 300W input and make sure that the driver will be below xmax. I am finding that *usually* the driver will reach xmax before its RMS input rating on ported designs. This is not a problem, as long as SPL when xmax is reached is acceptable for your needs. Theres a graph for that in WinISD too
The power of Science compels you! |
#23 | |
Yes most people accept 34 m/s (10% speed of sound) but people with higher standards get to 5% so 17 m/s. 16.4 is perfect. Like Dcibel said, check excursion, you probably need less than 300W.
DIYaudio for President ! |
| Please comment this design | promise | Solid State | 0 | 20th January 2005 05:25 AM |
| Pls Comment on My MTMWW Design | kestrel200 | Multi-Way | 24 | 2nd April 2004 02:30 AM |
| Plinth design for comment | Kanga | Multi-Way | 13 | 23rd September 2003 03:47 PM |
| First speaker design - please comment | sobazz | Multi-Way | 19 | 19th May 2003 10:23 AM |
| comment on this design, please. | JAZZ2250 | Tubes / Valves | 6 | 24th November 2002 10:45 PM |
| Page generated in 0.07852 seconds (64.45% PHP - 35.55% MySQL) with 10 queries |
