Old 31st March 2005, 12:44 PM   #1
ozone is offline ozone  United States
Default Sub question
I have some powered subs but it can only take up to 50 Watts so I was wondering if I pulled the box open could I just switch the speaker inside of it for a better speaker or do I have to rewire the whole thing up
Old 31st March 2005, 12:59 PM   #2
The box is most likely optimised for the driver in there. A better driver would probably have different T/S-parameters and therefor ask for a different enclosure.
If you more than 50 W perhaps you have the wrong speaker for the job.
Mvg Johan
Old 1st April 2005, 12:05 AM   #3
Speakerholic
Cal Weldon's Avatar
ozone,
It may be that the amp that is driving the system is only 50 watts, so you would have to renew the amp. If this is the case and you might also need to up the woofer, which means starting again.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st April 2005, 08:53 AM   #4
Default speaker replacement
Sure you can replace the driver.
Find the cubic volume of air in the cabinet, also the tuning frequency of the port. You will need the surface area and length of the port to figure that out.
Once you have that information, you should be able to find another woofer that will work in the cabinet without any problem.
If it is an amplified sub-woofer, that is a different problem. The amplifier built in would still be the same and this wouldn't help. You would then need to replace everything.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 11:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 03:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 02:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 07:03 AM
Page generated in 0.07497 seconds (65.63% PHP - 34.37% MySQL) with 10 queries
