I need qts and VAS parametar for monacor sp-300pa (12in) . I only know fs=40Hz.
#2 |
Well, I can give you a good guess on the Qts, but not the Vas.
If you look here from the Monacor website, you will see that at Fs, the SPL is about 85 dB. that is about 8 dB les than the rated midband of 93 dB, therefore the Qts is about 0.4, more or less. My guess the Vas is somewhere around 4 cubic feet, (113 liters), but don't hold me to it. My personal guess is to stick into a 3 cu ft, (85 liter), box tuned to 50 Hz, (4 inch diameter or 100 mm) and 1.5 inches long (38mm). Or you can lengthen the port to tune to 40 Hz-that would require a port 100 mm diameter by 100 mm long. Then decide which sounds better. You have a pretty good chance of being close to right.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#3 |
The other possiblity is to email Monacor from this page:
http://www.monacor.com/int/en/mail.html?spr=EN Ask them for the Thiele-Small specs or, if they don't have them, for a recommended box size and tuning. I am sure they have some idea of what size and tuning of box would work well with the speaker.
| What about Monacor? | mr_push_pull | Multi-Way | 8 | 17th October 2010 11:41 PM |
| Monacor sph-135/AD | Tomac | Multi-Way | 22 | 30th August 2006 05:30 PM |
| Monacor MSH-115 (116) | Michail Bugaria | Multi-Way | 5 | 16th May 2006 08:45 AM |
| Monacor | Vedo | Multi-Way | 2 | 10th February 2005 10:31 PM |
| Monacor SPH 130 AL - anyone? | andyjevans | Multi-Way | 10 | 8th December 2004 02:43 AM |
| Page generated in 0.20803 seconds (26.80% PHP - 73.20% MySQL) with 10 queries |
