Old 23rd March 2005, 08:33 PM   #1
mik is offline mik
Default This driver and EBS alignment
Hi guys,
I need help with this driver from you experts .My intention is to build subwoofer for my HT and after lot of reading I discasrded my first plan to use this driver with LT mainly because this aligment require lot of amp power and decided to go with EBS.Since this driver is fairly cheap I think that is good for first subwoofer project.For information my front speakers will be Dayton III and center Triuna , you can find them in PartsExpress project Showcase .So here are the questions:
Is can it be used in EBS alignment?
Second question is what type of active filter match this alignment?
Thanks in advance!
Old 23rd March 2005, 09:03 PM   #2
tiroth is offline tiroth  United States
Xmax is quite low for a sub.
Old 24th March 2005, 09:33 AM   #3
mik is offline mik
Thanks!
What about this or this
Old 25th March 2005, 06:50 AM   #4
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
The AXX 1515 has potential.
Download winisd pro from www.linearteam.dk and see how it looks.
The Visaton driver is low power,and doesnt reveal Xmax rating. You can calculate xmax from Hg and Hc[input these into winisd ]
Compare these drivers to the 'adire audio shiva' which are preloaded into winisd pro :-)
read the helpfiles in winisd.
Active filter is easy- 2nd,3rd or 4th order at 60hz-100hz.
Cheers!
Old 25th March 2005, 04:04 PM   #5
mik is offline mik
Thanks Mike!
I already have WinISD so i will try it and then I will post results.
Old 26th March 2005, 10:54 PM   #6
JMB is offline JMB  United States
Hi Mike.e,
What do Hg and Hc stand for and do you happen to know the formula used by WinISD to calculate Xmax?
Thanks.
Old 27th March 2005, 02:19 AM   #7
mike.e's Avatar
Its stated in the winisd helpfile!
,There are one or two calculations. They are approximate,i never fret over 10% differences in xmax
Coil gap and height or something,its been a while since ive used those inputs-i dont normally need to
Vertical WTMW driver alignment - pros and cons jb0194 Multi-Way 1 16th November 2008 10:20 PM
QB5 Alignment bigboy Multi-Way 1 19th September 2008 10:16 AM
Sig gen for FM alignment, diy? Conrad Hoffman Parts 10 16th December 2007 12:02 AM
driver offset - time alignment vs diffraction deiksac Multi-Way 4 28th August 2006 05:42 PM
Driver Alignment Nm2285 Multi-Way 10 26th July 2005 12:33 AM
Page generated in 0.10023 seconds (68.92% PHP - 31.08% MySQL) with 10 queries
