diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Wadding / stuffing (http://www.diyaudio.com/forums/subwoofers/53899-wadding-stuffing.html)
Howard 20th March 2005 06:29 PM
Wadding / stuffing
Would adding some acoustic wadding to the inside of a ported subwoofer make any difference to the sound?
How would it affect it?
crippledchicken 20th March 2005 09:15 PM
Re: Wadding / stuffing
hi Howard, usually ported subs don't benefit from stuffing nor, is it needed due to such a low crossover point. from what i've heard, good bracing is important though especially, on large enclosures.
Volenti 21st March 2005 08:19 AM
Stuffing damps resonance, this is not always easily heard but it's effect is easy to measure (drivers impedance at resonance is reduced (damped)).
Since a vented enclosure more or less works by resonance stuffing it will reduce output, this can be helpfull if the tuning is too high and it has a peaky/boomy sound but is otherwise detrimental to performance.
ie; if it sounds bad try stuffing it, it's an easily reversable tweek.
bremen nacht 8th January 2006 01:29 PM
What about in a full-range ported cabinet? The cabinets I'm building are 100 litres, and I'm going to control panel resonance with plasterboard and much bracing, should I also be using wadding and if so how much and where?
Crossover is 1kHz and th edrivers are Tannoy 12" HPDs.
Volenti 8th January 2006 11:00 PM
I'd line the walls with about 1'' thick sheet wadding and double or triple up the thickness directly behind the driver, massively complex bracing can also have a damping effect and help to break up standing waves also.
simon5 9th January 2006 06:28 AM
Stuffing a ported subwoofer will lower the tuning point because the box will be acoustically bigger. You could cut the pipe a bit shorter to counteract this.
Collo 9th January 2006 08:50 PM
Damping in ported subs
I use damping in ported subs, only where I need to control standing waves.
Usually the problem is the longest dimension on a tall box, so I use foam sheet on the top and bottom surfaces, which are zones of high pressure. For a deep box, I line the back panel as well.
Note that since the velocity at a wall boundary is zero, there is no advantage in using acoustic wool on the walls
The centre of the cabinet is a zone of high velocity, so I make sure I design in a shelf brace which has acoustic wool stapled across the cutouts.
I also ensure that the wool is not between the port intake and the driver - I don't want to lose any energy from the port. ;)
regards
Collo
Resources saved on this page: MySQL 18.75%
