I've heard very good things about this driver the EMINENCE LAB12 and speaking to BK electronics in the UK, they seem to think it would work in a 50 litre sealed box, similar to the Adire Shiva.
I wondered what plate amp I could use to partner up with it ? Parts Express sell the driver, and also some switchable voltage plate amps at about 250w and I wondered if this would be enough to drive it, seeing as though I could order both at the same time and shave a little off shipping charges. |
#2 |
Post the T/S parameters.
Davy Jones |
#3 |
Resonant Frequency (fs) 22Hz
Impedance (Re) 4.29Ohms Coil Inductance (Le) 1.48mH Electromagnetic Q (Qes) 0.39 Mechanical Q (Qms) 13.32 Total Q (Qts) 0.38 Compliance Equivalent Volume (Vas) 125.22litres Mechanical Compliance of Suspension (Cms) 0.35mm/N BL Product (BL) 15.0 T-M Voice Coil Overhang (Xmax) 13mm Surface Area of Cone (Sd) 506.7cm2 |
#4 |
x
Davy Jones |
#5 |
Dave
Seems as though this would benefit from the same 4dB boost at 20 Hz that you applied when modelling the Dayton Titanic's response. |
#6 | |
Davy Jones |
#7 |
You don't hang around ! Just compared it to the one you did with the Dayton and the Titanic seems to just edge ahead.
#8 |
EQing sealed box + high SPl requirement =
use ported. When comparing the subwoofers keep SOMETHING equal eg : box Vb required for maximally flat alignment for all,or equal volume for all to compare efficiency and cutoff.... Use winisd pro + patch to see excursion soar due to EQ applied to high excursion sealed box area below Fcb |
#9 | |
Davy Jones |
#10 |
True he smallangryboy didnt state what SPL he requires.
| FS: Eminence Lab12 Generation II 12" Subwoofer | Derrick | Swap Meet | 0 | 25th October 2008 06:53 PM |
| have lab12, looking for box design | massappeal129 | Multi-Way | 1 | 31st January 2006 03:36 PM |
| Eminence LAB12 in a dipole woofer? | Hennie | Subwoofers | 3 | 8th January 2005 10:30 AM |
| Shiva or Lab12? | richie00boy | Multi-Way | 54 | 23rd April 2004 09:33 AM |
| Eminence LAB12/any take on this one? | peterpan | Multi-Way | 4 | 18th April 2004 07:57 PM |
| Page generated in 0.09144 seconds (81.71% PHP - 18.29% MySQL) with 11 queries |
