Hooking up a third sub??? - diyAudio
Old 8th March 2005, 08:26 PM   #1
brock24 is offline brock24  United States
Thumbs down Hooking up a third sub???
I have a pair of Definitive Technology BP 7006 which have built in 8" 300 watt subs. Right now I have both of them hooked up to my an Integra receiever LFE. So right now I am using a splitter for both of the subs. I feel like they don't hit the low tones like my 10" sub did. My question is do you think it would hurt the receiever by splitting it again and having it split three ways to the three different subs.
Old 9th March 2005, 01:45 AM   #2
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
firstly define what the splitter is doing
If its doing what I think it is,your are going to run 3 subs in parallel,thus dropping your total impedence to dangerously low levels.
To run multiple subs properly you need to be running a load that the amplifier can handle,while placing the subwoofers correctly in room.
Old 9th March 2005, 02:02 AM   #3
Bill Fitzpatrick's Avatar
Since the woofers are driven from a built in amp, you should be OK splitting again and driving another active sub. On the other hand, if your 10" active sub has a built in electronic low pass filter (probable) you might run into bass quality problems due to the low pass filter from LFE + the low pass filter from the 10" sub.
Need help hooking up subwoofer. justpoor Subwoofers 3 13th August 2006 04:49 AM
Hooking up powered sub to PC ma_tt316 Subwoofers 10 15th January 2006 11:11 PM
help with hooking up transformer to IEC and psu Joseph0 Solid State 0 19th August 2005 05:57 AM
Hooking up VU meter? Jasmeleg Solid State 13 12th June 2005 11:13 AM
Help hooking up a uP tobias_svensk Digital Source 0 15th May 2005 12:42 AM
Copyright 1999-2017 diyAudio
