help tuning push-push ApexJr super 8 woofer
Old 5th March 2005, 09:22 PM   #1
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default help tuning push-push ApexJr super 8 woofer
I was frustrated getting reasonable results out of the MJK worksheets (i will revist that at some point) so we went ahead and threw together a push-push bass reflex based on the Super 8 4th order on Steve's site.
All i can measure is the impedance curve -- but i'm sure to someone more familiar with BR the shape of those 2 humps tell a lot... any suggestions on optimizing the tuning?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th March 2005, 09:23 PM   #2
frugal-phile(tm)
planet10's Avatar
And here are the drawings from which it was built...
Old 5th March 2005, 09:33 PM   #3
frugal-phile(tm)
planet10's Avatar
And what it actually looks like -- only the finest scraps were used...including recycled venerred particle board from some old speaker, 40-yr old plywood, the top from a console hifi, and part of a rejected table top with inlaid marquetry (currently the back of the speaker (i think i'll move the terminals to the face you see).
Old 5th March 2005, 09:34 PM   #4
frugal-phile(tm)
planet10's Avatar
I think these speakers have potential... currently hooked up as an HT woofer only using the XO out of the decoder, each driver driven by a channel of a Don Stenton Signature SS amp (50W/channel).
Starting to break them in -- Frank Zappa's Baby Snakes DVD on ATM.
Once i remove the base i'll play a bit with port stuffing (i'm much more comfortable with aperiodic).
The HT Processor doesn't have enuff adjustment to turn them down enuff... i'll be breadboarding up some XOs to see what we can do to improve on that.
dave
Old 8th March 2005, 04:09 AM   #5
BassAwdyO is offline BassAwdyO  United States
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
You dont have any driver specs? What a shame...
that bottom firing port is a bit strange, I would imagine the way it is configured like that makes the effective port longer than just the part that goes inside the box.
The golden rule of DIY:
Build nice, or build twice!
Old 8th March 2005, 05:05 AM   #6
frugal-phile(tm)
planet10's Avatar
Driver specs are in the pdfs....
dave
Old 8th March 2005, 09:02 AM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Hmm, I can see why Chris never lets you loose on the woodwork!
Well, it looks like you nailed the alignment fairly well, the well smoothed first peak being very indicative of the higher order alignment. The second peak is a little wide, but that is probably due to slight differences in the drivers blurring the curve.
Is that impedance curve calibrated, or just relative?
That looks very like a good HT sub for the money, I would be a bit wary using it as a music sub, though, the group delay is "interesting", though I have seen worse.
So, when is Jason going to build your mic pre, so we can see some frequency measurements?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 8th March 2005, 06:17 PM   #8
frugal-phile(tm)
planet10's Avatar
calibrated. I'm using Fuzzmeasure for OS X.
It is all i can use it for at the moment due to XO issues. Jason came out to assemble the new XO on breadboard on Sunday, but ended up watching cooking shows instead. He wanted to do it so i left it for him... i'll do it myself now.
It is sitting in a box all assembled... have to assemble the mic wand & test it... the new 1.2 beta of Fuzzmeasure has a whack of updates, but all have to do with measuring so i am eagar to see what it does.
dave
Old 8th March 2005, 09:40 PM   #9
SCD is offline SCD  Canada
Default Fine Woodworking?
Sooooo, you decided to show off some of my fine woodworking. I must say you got the photo from a good angle. I am glad it is just a prototype. Maybe a can of black paint will bring the best out of that fine looking box I made? All in all it was an hour or two well spent. Besides I was just going to burn the wood anyway.
I am sure you will figure out how to make sound better than it looks. Then we can show off a nicer cabinet.
SCD
Old 8th March 2005, 09:57 PM   #10
mateo88 is offline mateo88  United States
Would substituting a pair of those 8" MCM woofers work okay? Looks like a good plan for me if it will.
help tuning push-push ApexJr super 8 wooferHide this!Advertise here!
Isobaric push-pull with Dayton IB woofer tinitus Subwoofers 8 7th December 2010 12:32 AM
Push-pull woofer alignment 3-LockBox Subwoofers 0 26th June 2007 02:40 PM
Photos - My first T-Line Push-Push Subwoofer :) Xmax BR Subwoofers 6 23rd June 2005 08:17 PM
damaged cone usage (push push?) kneadle Multi-Way 24 27th January 2003 04:51 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
