help tuning push-push ApexJr super 8 woofer
Old 27th September 2005, 09:56 AM   #21
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by jdybnis
What kind of cross brace did you use between the two drivers? I'm thinking of epoxying a few hardwood dowels between the backs of the drivers.
The structural brace between all the side walls was notched so that the magnets butted up against it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th September 2005, 02:24 PM   #22
jdybnis is offline jdybnis  United States
I'll give that a shot before I start messing with epoxying the drivers.
Old 28th September 2005, 04:00 AM   #23
GM is offline GM  United States
GM's Avatar
Greets!
Just plugging the numbers into the ML-TQWT WS I get a T/S max flat with some peaking at Fb and another program calc's a bit high vent mach, so the need to 'stick a sock in it' is understandable.
FWIW, last year I took a look at this driver for someone and came up with this T/S max flat Voigt style dual driver pipe, but if they built it I never heard back, so as always YMMV:
L = 54"
SO = 1.122"^2 (physically comes to a point)
SL = 130.452"^2
rp = 2.121" (for simmimg purposes, build using dual 3" dia.)
Lp = 13"
drivers down 35.38"
It sims somewhat better damped for its much greater Vb than the BR of course, but like any max flat alignment it may sound a bit 'one note' in-room with this low an Fb, so I recommend bottom firing and possibly some vent damping for it also if near a wall or corner.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
help tuning push-push ApexJr super 8 wooferHide this!Advertise here!
Isobaric push-pull with Dayton IB woofer tinitus Subwoofers 8 7th December 2010 12:32 AM
Push-pull woofer alignment 3-LockBox Subwoofers 0 26th June 2007 02:40 PM
Photos - My first T-Line Push-Push Subwoofer :) Xmax BR Subwoofers 6 23rd June 2005 08:17 PM
damaged cone usage (push push?) kneadle Multi-Way 24 27th January 2003 04:51 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
