suitable amp for this subwoofer? - diyAudio
Old 28th February 2005, 09:37 PM   #1
Default suitable amp for this subwoofer?
my electronics teacher just gave me a non working subwoofer today, an infinity BU-120. it looks to be not bad. the amp was blown so i tore it out, and covered the back hole with a piece of plexi and sealed it with some bathroom sealer i had laying around. right now im looking to build an amp but i dont know what i should make. ideas?
i cant find too much info on the sub but its 12" and it was originally 150 watts.
from infinity: http://www.infinitysystems.com/homea...&Submit=Submit
sorry if this should be in a different forum, ill go to the appropriate amp forum when i get an idea of what i need. im pretty new at this diy audio stuff, so dont overfill me with jargon
Old 28th February 2005, 10:42 PM   #2
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
Get an amplifier with an RMS rating close to the RMS rating of the driver in question. Consider excursion also [winisd pro from linearteam.dk]
Plate amps are quite value for money.
Cheers!
Old 28th February 2005, 11:28 PM   #3
Apex Jr is offline Apex Jr  United States
Default Sub-Amps
Check out my website at www.apexjr.com
under the amplifier section and I would suggest
either the Apex "Junior" or the AudioFile VRS 1205
to use with the Infinity driver...
Steve @ Apex Jr.
Old 2nd March 2005, 05:03 AM   #4
simon5 is offline simon5  Canada
I'll suggest to look at plate amps from PartsExpress also.
DIYaudio for President !
Suitable Drivers For My Subwoofer Amp rikhav Multi-Way 2 10th January 2007 11:41 AM
Suitable bias for 4 ohm subwoofer over 200W? EWorkshop1708 Solid State 12 21st January 2006 05:09 PM
Suitable subwoofer to match FRS 8 Cyburg's Needle stobiepole Full Range 1 22nd December 2005 10:14 AM
Is normal 3/4 of an inch plywood is suitable for a subwoofer? simon5 Subwoofers 37 29th December 2004 09:19 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
Copyright ©1999-2017 diyAudio
