I used winISD pro to model a Dayton quatro 15"in a br and came up with this ; 7.3 cu. ft. with a 4"x8.4'' port. I'm not sure if this is right, because of others i've seen use a much longer port&smaller box,(winISD says -3 db@20 hz). Is this right or wrong? If it's wrong what was my mistake?
#2 |
Your box is well designed. You could go down to 6.5 cu. ft with a 10 inch long 4" diameter port, this will be a bit closer to room gain in a standard room.
If you go smaller, the port need to be longer, that's why you saw that.
DIYaudio for President ! |
#3 |
Simon5, you are a good man thank's for your help!
| Wrong Voltage / current on BoZ... or Wrong Measuring ? | gionag | Pass Labs | 8 | 14th May 2008 12:24 PM |
| what's wrong with it? | bravesz | Digital Source | 6 | 27th September 2006 09:15 AM |
| Nad 310 Gone Wrong | Kajman | Solid State | 1 | 5th April 2006 03:25 PM |
| Page generated in 0.06374 seconds (70.73% PHP - 29.27% MySQL) with 10 queries |
